I have a device outputting a signal (-10V...+10V) referring to GND. Now I want to feed this signal into another device, that only accepts differential inputs (-10V...+10V).
Is it possible to just connect GND to one of the diff. input-pins and signal to the other diff. input-pin? Is there something completly wrong with this attempt?
Edit: Both devices are connected to a common ground.
When both devices are not connected in any other way except for their output and input terminals, you can just connect as described: connect GND to one of the diff. input-pins and signal to the other diff. input-pin.
connections in any other way include shared earth or chasis or signal ground.
EDIT after new presented information
Devices that allow for differential inputs sometimes also specify an allowable common mode voltage. Check the datasheet of the input device for this allowed common mode voltage.
  • \$\begingroup\$ Actually they are connected to a common ground. What problem will this cause? \$\endgroup\$ Nov 27 '19 at 10:33
    \$\begingroup\$ Do edit your question with this relevant information. The more information you provide, the more useful answer you get. \$\endgroup\$
    – Huisman
    Nov 27 '19 at 10:39
