I was reading about single phase transformers. I came across these two terms 'full load' and 'rated' and they left me thoroughly confused.
In some places they're treated as the same thing, in others they aren't.
Are they the same thing? I know that rated values are those at which the transformer is meant to be used. If the two terms aren't the same, what is the distinction?
Also, suppose I were to apply rated voltage at primary side, what current and voltage would I get at the load? Would both of them be rated values?
In case the terms are different, what happens at the load when I apply full load voltage at the primary side? (Is full load voltage even a thing?)
Please help
