Storing an LED's previous state even if power is removed
I want to build a simple circuit that consists of 2 push buttons and an LED. I want the LED to turn on when one pushbutton is pressed and off when the other is pressed. I am pretty sure this can be done with a flip-flop. But this is not the only part. I also want the circuit to keep its previous state even if power is removed. So if the LED is on, and power is removed, I want it to be on when the power is added. Same with if the LED is off and the power is removed I want it to stay off when power is added. I think that NAND gates or something are used to store flash data, but I am not sure. I want this circuit to be only consisting of transistors and other common parts like capacitors resistors diodes crystals inductors ect... I don't want to use any uncommon integrated circuits (I only have 555 timers and some dual flip flops and some buffers and a few other really odd ic's.
This may be impossible (especially with only transistors) but any information is helpful and I'm only 14 so I'm still a beginner in this stuff.
Edit: I want to figure out a semiconductor way to do this. I know I don't have the parts but what would I need?
