Recently I was studying about alternating currents and transformers and I got confused about some of the concepts. I tried a lot of sources but none of them seemed to address the problem.
I understood that in a purely inductive DC circuit, the EMF of the source is exactly equal to the back EMF from the inductor at all times (due to KVL) and the current increases linearly with time.
In case of a purely inductive AC circuit, the net EMF is still \$0\$ at all instants and the current follows a sine curve and lags behind voltage by \$\pi/2\$ rad.
Please tell me if I've got something wrong in my understanding or misinterpreted something. I'll be very grateful.
Now my problem:
In an ideal transformer, if the secondary coil is open, the primary coil just behaves like an ideal iron-core inductor since the secondary coil has no effect. Hence the current in the primary coil must be there lagging behind the voltage by 90 degrees.
What I think is there will be a changing current flowing in the primary coil just enough to maintain the necessary back EMF. Here are a few articles I read.
- http://www.electricalunits.com/transformer-on-no-load/
- https://www.electronics-tutorials.ws/transformer/transformer-loading.html
- this Quora post (please see Steven J Greenfield's comment below)
If that's the case the back EMF has to be equal to \$-V_0\sin\omega t\$ which is precisely opposite to the applied voltage and that's the case of ideal inductors as I mentioned in the beginning. I think that this is what should really happen neglecting losses and other non-idealities. Again I may be wrong so please correct me.
But I also found some posts talking about the current in the primary coil being zero.
Here are a few posts which talk about this:
Moreover if the current were always zero in the primary coil under no load, that would mean \$\frac{\text dI}{\text dt}\$ is 0 so no back EMF would be induced and it'd be a short since there would be no resistance.
Actually I'm confused about whether or not the primary current at no load will be zero.
Please tell me where I've gone wrong and if something I mentioned is wrong.
