I have quite simple question about topology of superheterodyne. I am facing with adjacent channel selectivity problem.
The problem is that I can't obtain selectivity more than 40 dB. F.e. when wanted channel frequency signal had ampl. level 1 dBuV and adjacent channel frequency ampl. have more than 40 dBuV receiving process is broken. Both frequencies are provided to antenna circuit by sumator. Similar problem - 20 dBuV (wanted freq.) and 60 dBuV adjacent freq.
It is not a issue of IF filters stage - problem doesnt't occur when IF frequencies are directly modulated and provided to IF stage skipping first mixer and LNA stage. Then almost 85 db selectivity is obtained.
The problem is VCO (to first mixer) frequency reference from crystal. Due to phase noises output frequency (from VCO) to first stage mixer have only 40 dB difference of amplitude between center frequency and + / - 20 kHz.
So, if any adjacent channel frequency have amplitude 40 dB bigger than wanted freq. channel it's mixed with phase noises from crystal / VCO and have higher amplitude than wanted frequency (so it is totally corrupted).
The question: Is there any topologies or f.e. limiters / attentuators at the RF antenna signal stage to limit unwanted signal without limiting wanted 40 db lower signal?
Thanks for any answers.
