I have an Allen Bradley ControlLogix 11756-L72S PLC with a 1734-OE2V 2-Point Analog Output card connected to a SMC pressure regulator that takes a 0-10 V input signal to set the pressure setpoint.
I want to test that the loop is scaled correctly. I'm thinking that I'll enter the setpoint at the HMI and verify the voltage at the input. So with a setpoint of zero (0) psig I would expect 0 V at the input and with a setpoint of 75 psig I would expect 10 V the input, which would then be configured at the device to correspond to 75 psig.
Is this a good way to test analog output scaling? Is there anything I'm missing?
