What's the difference between a += 1
and a = a+1
in Verilog?
always_comb begin
a = '0;
a += 1;
end
always_comb begin
a= '0;
a = a+1;
end
Is the 2nd case a combinational loop?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communitya+=1
is just a short-hand for a=a+1
. They both are equivalent.
There is no combinational loop in both cases.
a
will be simply driven 1
in both cases. Synthesiser usually flags this as warning or info.
These are equivalent assignment statements in SystemVerilog—there is absolutely no difference. And the two always_comb
blocks do absolutely nothing as they have no sensitivity to any variables. In fact, some tools may generate warnings or errors stating that the blocks do not represent combinational logic.
always_comb
will run once per IEEE1800-2017 § 9.2.2.2.2 always_comb compared to always @* "always_comb
automatically executes once at time zero, whereas always @*
waits until a change occurs on a signal in the inferred sensitivity list."
with=+
because those expressions are different. \$\endgroup\$
