In amplitude modulation, the amplitude of the carrier wave is changed according to the variations in the message signal, and that's what we draw inside the two envelops of the message signal, that's totally fine, but what is confusing to me, that we never changed the frequency of the carrier wave, then why do those two sidebands appear in the frequency response of the AM wave, I know that the mathematics works out to be like that, but how on the earth they appear in first place, when we never tried to mess with the frequency of the carrier?
  • \$\begingroup\$ What do you get if you mix two frequencies? \$\endgroup\$
    – JRE
    Dec 3, 2019 at 7:00
  • \$\begingroup\$ @JRE A mixture of both, but when doing the math we consider a single carrier frequency and a single message signal frequency, but we are just shifting the amplitude right? And if the new frequencies get mixed up, then why don’t we see in the AM modulated wave diagram? \$\endgroup\$ Dec 3, 2019 at 7:13
  • 6
    \$\begingroup\$ An AM transmitter is a mixer. It mixes the low frequency message signal with the high frequency carrier. \$\endgroup\$
    – JRE
    Dec 3, 2019 at 7:17
  • \$\begingroup\$ @JRE So there is frequency deviations in AM modulated wave, its not a pure carrier wave frequency, but we don't see it in all the visual illustrations, is it because the changes are quite small? \$\endgroup\$ Dec 3, 2019 at 7:51
  • \$\begingroup\$ A square wave of period T contains infinite number of frequencies. Can you see all those frequencies in an oscilloscope? \$\endgroup\$
    – Mitu Raj
    Dec 3, 2019 at 8:17
5 Answers 5
7
AM means that the amplitude of the carrier is multiplied by the payload signal plus some offset.
The multiplication theorem for sine says
\$\sin(a) \cdot \sin(b) = \frac{1}{2} ( \cos(a-b) - \cos(a+b))\$
Let \$a=2\pi f_c t\$ be the carrier phase and \$b=2\pi f_s t\$ the phase of a sinusoidal payload signal then as a result of AM (=multiplication of sines) you get a sum of two sinusoids. The frequency of one of them is a little bit below (\$f_c-f_s\$) and one of them a little bit above (\$f_c+f_s\$) the carrier frequency.
This works not only for a payload signal that is a pure sine wave but also for a whole band (any signal can be seen as a sum of sinusoids).
So as a result you get one band above and one (mirrored) below the carrier frequency.
(Note: The offset mentioned in the beginning results in the fact that also the unchanged carrier frequency will be present after AM; but I've neglected that for simplicity).
BTW:
AM does mess with the frequency. It's a missconception that multiplication of two signals wouldn't mean messing with the frequency; that's true only for multiplication by a constant; that's a linear operation; multiplcation of two time varying signals is not. Any non-linear operation introduces new frequencies.
Simple example: frequency doubling (=messing with frequency) of a sinusoid can be done by simply squaring the signal (=multiplying by itself).
  • \$\begingroup\$ Thankyou, you explained it very well, gotcha right in my head. \$\endgroup\$ Dec 3, 2019 at 12:13
Only a constantly running sinewave that has no amplitude or frequency variations has a single frequency peak. If there is any time varying modification at all to amplitude or phase, it is not a single pure sinewave any more and so it must have other frequencies as well. If it helps to think the other way, don't think of message signal modulating a carrier, as in AM it is equal to think that the carrier modulates the message signal.
Those sidebands were there in the original unmodulated message signal.
Consider that your message signal is a 1 kHz sinewave of constant amplitude and it is multiplied by 1 volt DC. This is just a thought experiment because we know intuitively that the resulting signal is no different to the original message signal but, read on.
The 1 volt DC signal is constant and it therefore has a frequency of zero Hz. Knowing that if you multiply two sine waves you get sum and difference frequencies, the result of 1 kHz multiplied by 0 Hz produces sidebands of -1 kHz and +1 kHz.
So, we can say that the sidebands were present in the original message signal.
When modulating a real carrier (say 100 kHz) you get sidebands of 99 kHz and 101 kHz - in effect, the act of multiplying (called mixing by RF people) is to shift the baseband signals (negative and positive frequencies both) up by 100 kHz.
So now the can of works of negative frequencies is opened (another question I suspect).
  • \$\begingroup\$ Thanks a lot, I got the concept. \$\endgroup\$ Dec 3, 2019 at 12:15
And that is all you need to know.
Here's the result of adding 3 sine waves; 0.4V of 980Hz, 1V of 1000Hz, and 0.4V of 1020Hz:-
Nothing was messed with, just 3 separate waves sent down a single wire. And yet we can see a 'carrier wave' and 'modulation'.
But can we develop a circuit that reproduces that waveform without needing 3 separate oscillators? Turns we can, by simply varying the voltage of the 1kHz wave. So by 'messing with' the amplitude of the carrier wave we have created the same effect as those 3 separate waves.
Demodulating it is also pretty easy. Rather than trying to separate out one of the sidebands and subtracting 1KHz from it to get 20Hz, we can simply 'rectify' the whole waveform with a diode and filter out the carrier frequency with a capacitor (which doesn't work perfectly, but is close enough for most purposes).
Compared to other modulation schemes such as FM and SSB, AM seems complicated. But the circuits used to produce and demodulate it are simple. If that wasn't the case we probably wouldn't use it, since it makes inefficient use of both power and bandwidth.
Simply because the amplitude modulated wave can be broken down into superposition of 3 sine waves of carrier frequency(fc), (fc-fm) and (fc+fm) and in general frequency domain analysis is actually visualizing the signal by how many sinusoidal waves it is composed of.
When it is only carrier wave it is composed of only one sinusoidal frequency but when it is amplitude modulated it is no longer a normal sinusoidal wave its a different waveform/signal all together. And according to Fourier each waveform(sinusoidal/non-sinusoidal) can be represented as the sum of sine waves of different amplitudes and frequencies. This is why AM wave when expanded consists of 3 different sinusoidal wave of 3 different frequency.
    \$\begingroup\$ This only repeats the observation in its various forms; it does nothing to explain why there are sidebands in the output. As such it makes no attempt to actually answer the question - a question that received actual answers a year ago. \$\endgroup\$ Nov 20, 2020 at 16:15
  • \$\begingroup\$ @ChrisStratton that sounds demotivating. Have I wrongly explained the answer because you told no attempt to answer the question. \$\endgroup\$ Nov 21, 2020 at 3:15
  • \$\begingroup\$ It's not that what you say is untrue, but that it does not answer the question asked. Unlike general discussion forums, this site has a strict question and answer format. \$\endgroup\$ Nov 21, 2020 at 3:52
