How can I solve for V0 on the next circuit if Z1 = 1, Z2 = j, Z3 = -j.
All the ways I'v tried, V0 depends ends depending on V0, maybe using superposition theorem?
Attempt 1: ( Calculating current through Z3, and use a current divider to get the current through Z1 or Z2, then multiply times the impedance used.)
Attempt 2: (Using net analysis for determining I1, I2 and I3, then multiplying (I2-I1) * Z2)
I need to measure what 2V0 is to solve for the impedance of the 1A source, Thanks!
  • \$\begingroup\$ Show the "ways you tried". \$\endgroup\$ – Eugene Sh. Dec 3 '19 at 20:06
    \$\begingroup\$ Sure, I was about to :) \$\endgroup\$ – Cheche Romo Dec 3 '19 at 20:08
  • \$\begingroup\$ Is it assumed that these are DC sources? And V0 referenced to where? \$\endgroup\$ – Aaron Dec 3 '19 at 20:27
  • \$\begingroup\$ @Aaron I am sorry yes these are dc sources, because I am trying to calculate Thevenin's equivalent impedance, and ground is the bottom node. \$\endgroup\$ – Cheche Romo Dec 3 '19 at 20:43
    \$\begingroup\$ How does DC current flow through Z3? \$\endgroup\$ – Aaron Dec 3 '19 at 20:46
