I have created an hydroponic system using modbus to communicate between a RaspberryPI server and plug&play arduino sensors. It works but as soon as I plug a sensor on the bus (physically), all the other plugged sensors are timed out for a couple of seconds.
The sensors are connected on the same PSU as the RaspberryPI.
I tried to power a sensor with another power supply (USB of my desktop computer) and everything works well. Other sensors are not timed out.
I tried to see what happens with an oscilloscope (on modbus lines A & B) but I can't interpret the result and I don't know how I could make them work on the main power supply. My electronics skills are very limited.
Here are pictures of the recorded data:
Thanks for your time !!
