This clamp is being used on a piece of equipment that is a few years old. I am trying to identify the type of clamp this is. If you the reader cannot identify it, leave a comment with something similar that will not damage thin wire when clamped.Image of clamp
  • \$\begingroup\$ type in test clips into mouser or digikey and browse al the images \$\endgroup\$ – DKNguyen Dec 6 '19 at 1:29
  • \$\begingroup\$ it's a type of aligator clip with smooth jaws. "MUELLER BU-34M" has similar jaws. \$\endgroup\$ – Jasen Dec 6 '19 at 1:51
  • \$\begingroup\$ Is this a Kelvin clip? Because it looks identical to the clips on my cheap Kelvin interface. Check wither both jaws have continuity. \$\endgroup\$ – GB - AE7OO Dec 6 '19 at 2:35
  • \$\begingroup\$ @GB-AE7OO Yes they are, thanks for the assistance. \$\endgroup\$ – Matt Dec 6 '19 at 21:25
Ok, they look like the Kelvin clips on my cheap pair, which look identical to this one. enter image description here Please note the insulated hinge found on both. Here is a set of clips from Amazon and one from Ebay. If so then you need to replace it with another Kelvin clip, like one of the following: Found at Amazon Found at Ebay AST Labs That is just a small selection.
  • \$\begingroup\$ Thanks, I appreciate the links you provided. \$\endgroup\$ – Matt Dec 6 '19 at 21:22
6
It is identical to a Kelvin clip pair that I have. Mine have two coaxial cables and two BNC connectors per clip (so four in total for the red + black clips).
If you don't need the Kelvin feature (independent connections to each side of the jaws) there are plenty of small alligator clips.
  • \$\begingroup\$ Thank you for your help \$\endgroup\$ – Matt Dec 6 '19 at 21:22
