Can LTSpice used in the terminal by a command line? Is there any example there ? I only saw examples in Windows OS
How would simulating a circuit file using LTSpice using terminal in MacOS? (like using NGSpice in command line)
  • \$\begingroup\$ It looks like you answered your main question already for Windows OS. I'd suggest adding "on MacOS" to your title \$\endgroup\$ – Huisman Dec 8 '19 at 20:56
  • \$\begingroup\$ Oh yes, İ just edited the title, thanks \$\endgroup\$ – simo Dec 8 '19 at 21:13
  • \$\begingroup\$ Does this question answer your question? \$\endgroup\$ – user103380 Dec 9 '19 at 1:40
  • \$\begingroup\$ I tried it, but it will open the LTSpice app window, what I need is to execute it in the background without actually opening in \$\endgroup\$ – simo Dec 9 '19 at 5:44
Try this in your terminal .cir file can also be stimulated.
<Path\of\the\program>\XVII86.exe -b -Run file_name.asc
LTSpice simulation can be executed by batch process using command prompt
LTSpice Help > Modes of Operation > Command Line Switches
-b will execute .cir or .asc without opening LTSpice
