DC-DC Buckbooster vs M.P.P.T vs Solar Charger
  • \$\begingroup\$ No.Because Charcing algorithm is needed while charging a battery.It is not fit into buck converters constant voltage output. \$\endgroup\$ – emre iris Dec 9 '19 at 14:24
  • 4
    \$\begingroup\$ MPPT is an algorithm. Buck-boost is a switching technology. An MPPT algorithm can use whatever switching technology is most useful. \$\endgroup\$ – Andy aka Dec 9 '19 at 14:51
  • \$\begingroup\$ largely yes, if you only trickle charge or have another charge controller handle the battery details in a safe manner. you would be missing the battery management and max power extraction, but would end up with a a stable output voltage using only a BB DC/DC... \$\endgroup\$ – dandavis Dec 9 '19 at 17:57
This question is akin to asking "is it possible to use an engine instead of a car or an engine control unit?" - it doesn't make sense as they are components of each other, not alternatives. Your question can't get a meaningful answer.
In fact, a fairly typical solar charge controller will employ a maximum power point tracking (MPPT) algorithm to control a buck-boost DC-DC converter.
|improve this answer|||||
