Here is my LT-spice simulation of a simple circuit.
I need to find the voltage across R6, but Lt-Spice doesn't give me that information.
Does anybody know why this is or if there is something wrong?
Okay, I figured it out.
You can attach a little label right next to the resistor and then run the simulation.
  • \$\begingroup\$ Or ask LTSpice to indicate the node names it picked. \$\endgroup\$ – Andy aka Dec 9 '19 at 16:38
  • \$\begingroup\$ Or hover above a net while in the schematic editor and check the net name appearing in the left lower corner \$\endgroup\$ – Huisman Dec 9 '19 at 17:16
  • \$\begingroup\$ Or multiply the current I(R6) by the resistance of R6 \$\endgroup\$ – W5VO Dec 9 '19 at 17:25
It is there. It is one of the voltage nodes relative to ground so it is not associated with any one component.
