I have been working on an IC from Fairchild semiconductor named FL5150, whose electrical working I have tested by controlling the brightness of a lamp. Until now I have been using the circuit given in the datasheet with a manual potentiometer.
But one thing which I am not able to understand is the circuit in this portion. .
When the current passes through the MOSFET, the mid-point of both the MOSFETS is in direct line of AC supply. But that part is also connected to the Ground of the IC. How is this thing working? Is the voltage on the mid-point of both the MOSFETs at a constant voltage?
