I am using an STM32L4R5 board and am trying to configure the DMA on the UART2 line. I have managed to get the RX line to operate how I want, but when I follow "Transmission Using DMA" in section 44.5.19 of the "RM0432 Reference Manual" only one byte is transmitted and nothing else. This byte only gets sent when I explicitly write a byte to the TDR register. Afterwards, I can see the TC flag is cleared and the first byte of my DMA register is affected. How do I get the DMA to continously send out the data to the TDR for transmission?
Note: this problem seems to be simliar to an unanswered question here
The steps mentioned in the datasheet are as shown:
- Write the USART_TDR register address in the DMA control register to configure it as the destination of the transfer. The data is moved to this address from memory after each TXE (or TXFNF if FIFO mode is enabled) event.
- Write the memory address in the DMA control register to configure it as the source of the transfer. The data is loaded into the USART_TDR register from this memory area after each TXE (or TXFNF if FIFO mode is enabled) event.
- Configure the total number of bytes to be transferred to the DMA control register.
- Configure the channel priority in the DMA register
- Configure DMA interrupt generation after half/ full transfer as required by the application.
- Clear the TC flag in the USART_ISR register by setting the TCCF bit in the USART_ICR register.
- Activate the channel in the DMA register.
My code is here:
//filling in dummy info into my DMA TX buffer
memset((void*)DMA_USB_TXbuf, 0x55, 16);
//ensuring my UART is configured for DMA Transfer
huart2.Instance->CR3 |= USART_CR3_DMAT;
//steps 1-4 taken care of within this funciton
HAL_DMA_Start_IT(&hdma_usart2_tx, (uint32_t)&huart2.Instance->TDR, (uint32_t)&DMA_USB_TXbuf[0], DMA_USB_TX_SIZE);
//step 5 (just ensuring that we have the flags we want after the previous function)
__HAL_DMA_DISABLE(&hdma_usart2_tx);
__HAL_DMA_ENABLE_IT(&hdma_usart2_tx, DMA_IT_HT);
__HAL_DMA_ENABLE_IT(&hdma_usart2_tx, DMA_IT_TC);
//step 6
__HAL_UART_CLEAR_FLAG(&huart2, UART_CLEAR_TCF);
//step 7
__HAL_DMA_ENABLE(&hdma_usart2_tx);
//I shouldn't need to do this, but this seems to be the only way
// I get even 1 trasmission from DMA register
WRITE_REG(huart2.Instance->TDR, 0x55);
HAL_USART_Transmit_DMA()
? \$\endgroup\$ – Codo Dec 10 '19 at 15:51
