I am trying to control WS2812b digital LEDs with stm32f103. I have a buffer of color values for the LED strip and to transfer them I need to write the next value to the timer's CCR every time the timer updates. As the result I should see this buffer as a PWM signal on the pin of the MC. The guy, who helped me with the PCB wired LED's data pin to PB5 of the MC. PB5 is connected to TIM3_CH2. According to the manual there is no DMA request for TIM3_CH2. enter image description here Does this mean it is impossible to use DMA to change TIM3 CCR2 every time the timer updates? I know about the DMA burst mode which can write to any CCR of a timer, but looks like it is impossible to send a big buffer to one CCR. What am I missing?
    \$\begingroup\$ Haven't dug into the details of this lately, but any chance you could run another TIM3 OC channel in parallel and use that as a trigger unconnected to any pin, and have DMA load both? Are you sure the appropriate trigger to use actually is the channel specific one. \$\endgroup\$ Dec 10 '19 at 16:59
  • \$\begingroup\$ Hmm, do you mean that I can use any timer channel as an update event for the DMA? \$\endgroup\$
    – George
    Dec 10 '19 at 17:04
  • \$\begingroup\$ Another channel of the same timer would presumably need to be updated at the same time so a "fake" output on that (unrouted to any pin) might work as a substitute timing source \$\endgroup\$ Dec 10 '19 at 17:13
  • \$\begingroup\$ I thought TIM3 was more general purpose. micromouseonline.com/2016/02/04/… \$\endgroup\$ Dec 10 '19 at 17:16
  • \$\begingroup\$ Does this answer your question? stm32 which timer and DMA channel should I use? \$\endgroup\$
    – Tagli
    Dec 13 '19 at 7:19
Turned out I just needed to use TIM_CHANNEL_UPDATE as update source for the DMA and set TIM3 CCR2 as an output. It just works. I used HAL library and I had to create my own HAL_TIM_PWM_Start_DMA and HAL_TIM_PWM_Stop_DMA functions.
Here is the code, it contains hardcoded values for CCR2 and TIM_DMA_ID_UPDATE channel
HAL_StatusTypeDef HAL_TIM_PWM_Start_DMA_HACK(TIM_HandleTypeDef *htim, uint32_t Channel, uint32_t *pData, uint16_t Length)
    /* Set the DMA Period elapsed callback */
    htim->hdma[TIM_DMA_ID_UPDATE]->XferCpltCallback = TIM_DMADelayPulseCplt;
    /* Set the DMA error callback */
    htim->hdma[TIM_DMA_ID_UPDATE]->XferErrorCallback = TIM_DMAError;
    /* Enable the DMA channel */
    HAL_DMA_Start_IT(htim->hdma[TIM_DMA_ID_UPDATE], (uint32_t)pData, (uint32_t)&htim->Instance->CCR2, Length);
    /* Enable the TIM Capture/Compare 1 DMA request */
    __HAL_TIM_ENABLE_DMA(htim, TIM_DMA_UPDATE);
    /* Enable the Capture compare channel */
    TIM_CCxChannelCmd(htim->Instance, Channel, TIM_CCx_ENABLE);
    if (IS_TIM_BREAK_INSTANCE(htim->Instance) != RESET)
        /* Enable the main output */
        __HAL_TIM_MOE_ENABLE(htim);
    /* Enable the Peripheral */
    __HAL_TIM_ENABLE(htim);
    /* Return function status */
    return HAL_OK;
HAL_StatusTypeDef HAL_TIM_PWM_Stop_DMA_HACK(TIM_HandleTypeDef *htim, uint32_t Channel)
    __HAL_TIM_DISABLE_DMA(htim, TIM_DMA_UPDATE);
    /* Disable the Capture compare channel */
    TIM_CCxChannelCmd(htim->Instance, Channel, TIM_CCx_DISABLE);
        /* Disable the Main Ouput */
        __HAL_TIM_MOE_DISABLE(htim);
    /* Disable the Peripheral */
    __HAL_TIM_DISABLE(htim);
    /* Change the htim state */
    htim->State = HAL_TIM_STATE_READY;
    return HAL_OK;
