What's wrong with the following code? The array "FIFO" is declared correctly, but an error appears. Can you please help how to fix this?
module fifo(
    input clk,
    input [7:0]data_in ,
    output reg [7:0] FIFO [0:8]
integer i;
always@(posedge clk) begin
       for(i = 8; i > 0; i=i-1) begin
          FIFO[i] <= FIFO[i-1];
       end
       FIFO[0] <= data_in;
end
endmodule
Error (10773): Verilog HDL error at fifo.v(29): declaring module ports or function arguments with unpacked array types requires SystemVerilog extensions
Exactly what it says: you have a two-dimensional output port which is an unpacked array.
This is a packed array: output reg [7:0] FIFO
This is an unpacked array: output reg FIFO [0:7]
Therefore your two-dimensional array is an unpacked array.
Verilog allows only packed arrays for ports.
If you want two or more dimensions you need to compile with System-Verilog.
| improve this answer | |
