I am working on driving an 8 ohms speaker. I am currently modelling(in Ltspice) it just as an 8 ohms resistor. However this is probably far from being realistic. I don't want/need too much precision however. So how can I model a speaker with minimum complexity but also better than one single resistor?
  • 5
    \$\begingroup\$ This is easy to find using Google, for example: audiojudgement.com/speaker-equivalent-circuit \$\endgroup\$ – Bimpelrekkie Dec 11 '19 at 13:05
    \$\begingroup\$ This looks interesting. No time to evaluate it and make a summary. Maybe you could look at it and post an answer to your own question if the information in that link helps you. \$\endgroup\$ – JRE Dec 11 '19 at 13:10
    \$\begingroup\$ Do you want to model out the speaker using a mathematical model, or do you want to do a simulation in LTSpice using a basic circuit? \$\endgroup\$ – abunickabhi Dec 11 '19 at 13:32
  • \$\begingroup\$ @abunickabhi no, I actualy wanted something like the others linked. \$\endgroup\$ – muyustan Dec 11 '19 at 13:45
