TL;DR : I want to use a darlington transistor model(BD679&BD680) within LTspice. Can I do that by using default symbols npn or pnp from component selector menu?
I have done it with TIP41C & TIP42C, the downloaded file for them were like this:
* Spice Model
* Item: TIP41C
* Date: 8/11/10
* Revision History: A
* This model was developed by:
* Central Semiconductor Corp.
* 145 Adams Avenue
* Hauppauge, NY 11788
* These models are subject to change without notice.
* Users may not directly or indirectly re-sell or
* re-distribute this model. This model may not
* be modified, or altered without the consent of Central Semiconductor Corp.
* For more information on this model contact
* Central Semiconductor Corp. at:
* (631) 435-1110 or Engineering@centralsemi.com
* http://www.centralsemi.com
*SRC=TIP41C;TIP41C;BJTs NPN; Si;100.0V 3.00A 3MHz Central Semi Central Semi
.MODEL TIP41C NPN (
+ IS=290.83E-15
+ BF=113.55
+ VAF=100
+ IKF=1.9905
+ ISE=1.3946E-12
+ NE=1.4763
+ BR=.1001
+ VAR=100
+ IKR=10.010E-3
+ ISC=320.65E-12
+ NC=1.8994
+ NK=.58929
+ RB=.71129
+ CJE=348.44E-12
+ VJE=.78228
+ MJE=.42865
+ CJC=184.26E-12
+ VJC=.47897
+ MJC=.40458
+ TF=36.381E-9
+ XTF=100.32
+ VTF=21.563
+ ITF=28.791
+ TR=10.000E-9 )
I have just copied and added .MODEL part to the end of standard.bjt
file. And I was able to choose it from "pick new transistor" menu. So, I now downloaded the library file for BD680 darlington transistor but it is more complicated than the former TIP41C case.
* Model Generated by MODPEX *
*Copyright(c) Symmetry Design Systems*
* All Rights Reserved *
* UNPUBLISHED LICENSED SOFTWARE *
* Contains Proprietary Information *
* Which is The Property of *
* SYMMETRY OR ITS LICENSORS *
* Modeling services provided by *
* Interface Technologies www.i-t.com *
.SUBCKT bd680 1 2 3
* Model generated on Feb 14, 2004
* Model format: PSpice
* Darlington macro model
* External node designations
* Node 1 -> Collect
* Node 2 -> Base
* Node 3 -> Emitter
Q1 1 2 4 qmodel
Q2 1 4 3 q1model 2.46191
D1 1 3 dmodel
R1 2 4 8000
R2 4 3 120
* Default values used in dmodel
* EG=1.11 TT=0 BV=infinite
.MODEL dmodel d
+IS=1e-12 RS=10 N=1 XTI=3
+CJO=0 VJ=0.75 M=0.33 FC=0.5
.MODEL qmodel pnp
+IS=2.23835e-12 BF=149.682 NF=1.2 VAF=59.0895
+IKF=0.118079 ISE=9.09119e-14 NE=1.42175 BR=0.587475
+NR=0.75 VAR=100.388 IKR=0.0934405 ISC=9.09118e-14
+NC=2 RB=15.5445 IRB=0.450416 RBM=12.8364
+RE=0.0939759 RC=2.76027 XTB=0.497353 XTI=2.9942 EG=1.05
+CJE=1e-11 VJE=0.75 MJE=0.33 TF=1e-09
+XTF=1 VTF=10 ITF=0.01 CJC=1e-11
+VJC=0.75 MJC=0.33 XCJC=0.9 FC=0.5
+TR=1e-07 PTF=0 KF=0 AF=1
.MODEL q1model pnp
+XTF=1 VTF=10 ITF=0.01 CJC=0
.ENDS
So I assume I cannot just copy this into standart.bjt
file.
When I was also trying to use LM741, I added its library file in form of .sub
file to the /sub
folder of LTspice and I was able to use .lib LM741.sub
. I have been choosing opamp2
from component selector menu and just renaming its name to LM741 was sufficient. But this method did not work for BD680 darlington. I assume opamp2
for intended to be used with sub models however pnp
is not. But I am not sure.
So what can I do?
update: I think dragging the library file into LTspice and creating a new symbol can be one of the solutions. I have just figured it out. So, you can provide better solutions if you have any.
