I'd like to know what components are the ones with blue numbers and the big ones behind them:
The latter components I'm talking about:
image 3
    \$\begingroup\$ The ones with blue marking are capacitors. To get anything about the other ones, you'll need to provide a better-lit and more in-focus photo. \$\endgroup\$
    – The Photon
    Commented Dec 11, 2019 at 18:52
  • \$\begingroup\$ We need better an in focus pictures to be able to help you. \$\endgroup\$ Commented Dec 11, 2019 at 19:03
  • \$\begingroup\$ No, there isn't anything on them \$\endgroup\$ Commented Dec 11, 2019 at 19:04
8
As Jakob Halskov mentioned, those are 820 uF 25V aluminum electrolytical capacitors.
Those black "tall" components are flat wire iron core inductors, likely configured for the voltage regulators next to them. The CHOKE reference designator is proof that it is an inductor.
The silver and blue cylindrical components look like 820 uF 25V electrolytical capacitors.
  • \$\begingroup\$ OP also asked for the components behind the capacitors as well. \$\endgroup\$
    – user103380
    Commented Dec 11, 2019 at 19:06
The silver and blue capacitors I think are a Nippon Chemi-Con cap from their NPCAP-PSE series which is what the "E" is calling out. This would be an Aluminum Poly Cap. Looking closly it appear the bottom is a 2.5 and not 25 which would make it part APSE2R5ELL821MF08S
