For a BJT, we usually want to hard saturate it by assuming Beta value is very low. This way we can maximize the current at the collector. However, I am not sure what is the equivalent for a MOSFET transistor.
Is there anything similar to Hard Saturation for a MOSFET transistor? If so, how can it be achieved?
  • \$\begingroup\$ mosfet is a voltage controlled device unlike bjt which is current controlled. \$\endgroup\$
    – Mitu Raj
    Dec 12, 2019 at 6:12
  • \$\begingroup\$ @MituRaj Yes I know... and indeed MOSFET is acting like a resistor... in saturation mode its resistance should be close to 0. I am fear that if there any variation that will make this resistance goes out from saturation mode? Should I do anything at the gate to guarantee the MOSFET to run in saturation mode even in any extreme environment/factor? \$\endgroup\$
    – mannok
    Dec 12, 2019 at 6:18
  • \$\begingroup\$ If Vgs>2.5 to 3xVgs(th) you are typically achieving rated RdsOn. More Vgs helps but very little. \$\endgroup\$ Dec 12, 2019 at 7:12
You may not have heard of it because 'saturation' in a MOSFET is the opposite of a bipolar transistor. I think you are actually talking about keeping the MOSFET out of saturation and minimizing resistance in the linear region. This is achieved by maximizing Gate voltage, which is the FET equivalent of maximizing Base current in a bipolar transistor.
Here's an example of Drain current vs Drain-Source voltage for various Gate voltages on a standard power MOSFET. In the steep 'linear' part of each curve the Drain-Source channel acts like a resistor, so current is proportional to voltage. The flat part is where the channel 'saturates' and cannot pass any more current.
This particular MOSFET is rated for 50A maximum, so a Gate voltage of 10V is sufficient to keep it in linear mode well beyond its rating. At 5V it only stays in linear mode to ~15A, and also has higher resistance (which you can tell from the gentler slope below VDS of ~1V). It might still be usable for switching lower current, but this FET really needs more than 5V to ensure that it stays fully turned on at high current.
    \$\begingroup\$ I read your answer again and again... Yes... I misunderstood what "saturation" means \$\endgroup\$
    – mannok
    Dec 12, 2019 at 7:59
  • 4
    \$\begingroup\$ Please provide attribution as to where the picture came from unless you drew it yourself. \$\endgroup\$ Dec 12, 2019 at 9:58
  • \$\begingroup\$ @MichaelKaras I took the image from a pdf datasheet that I downloaded from somewhere in 2001. I added the part number thinking this would be sufficient attribution, but obviously it isn't enough for this site. The part is obsolete and I could not find any reference to it on ST's website . Hoping the link I added will be sufficient. \$\endgroup\$ Dec 12, 2019 at 17:33
A MOSFET will enter its saturation mode and leave the 'linear region' when an appropriate voltage difference between the gate and source has been achieved. For most N-Channel MOSFETS, this is between 8 and 15 volts. 12v Vgs is what I see most drivers providing MOSFETS these days.
To "guarantee the MOSFET to run in saturation mode even in any extreme environment/factor,"
You must ensure that Vgs never drops below the 'fully-on' range. Refer to your FET datasheet.
This is analogous to the way BJTs work. If you want a maximum output current, you must provide a minimum input current. With MOSFETS, if you want minimum output resistance and 'saturation,' where the FET effectively functions as a current source, you must provide a minimum voltage between the gate and source.
Here is a graph from the 06N03LA:
RdsON
You want your MOSFET to have the same resistance regardless of the current passing through. According to the graph, if Vgs is 10v, the MOSFET will behave like a current source, generating minimal heat in the transistor itself.
  • \$\begingroup\$ Sorry this may be a dumb question... for the BJT part you have mentioned "If you want a maximum output current, you must provide a minimum input current." Do I misunderstand? Does Output Current referring to Ic? Doesn't maximum output current comes from maximum input current? i.e. Ib = BIc \$\endgroup\$
    – mannok
    Dec 12, 2019 at 6:55
  • \$\begingroup\$ @mannok Your configuration in a BJT circuit must be able to source at least some current Ib to the base to get maximum collector current. If your configuration cannot meet this minimum, your output will NOT be saturated. \$\endgroup\$
    – Hackstaar
    Dec 12, 2019 at 7:04
    \$\begingroup\$ Please include a link as to where the picture came from. \$\endgroup\$ Dec 12, 2019 at 9:59
  • \$\begingroup\$ @Michael Karas added the link. Meant to include it but forgot. \$\endgroup\$
    – Hackstaar
    Dec 12, 2019 at 16:44
