I want to know if we can use both tvs and mov varistor together ?
What will be good for thrusters ? And placement between esc and thruster or before esc?
Update:
system voltage is power supply 48 volt then 2 buck converters then arduino and thrusters ( motor with propeller ) . I wanna protect arduino , converters from surge current and clamp voltages
  • \$\begingroup\$ These are probably not what you want for that. What is the system voltage? What are you trying to protect against? \$\endgroup\$ – Chris Stratton Dec 12 '19 at 7:07
  • \$\begingroup\$ Lowest capacitance clamp device draws the least normal current for I=CdV/dt. Then lowest incremental resistance results is best clamp. \$\endgroup\$ – Tony Stewart EE75 Dec 12 '19 at 7:15
  • \$\begingroup\$ Why would you want to use them together? What is a thruster? What is an esc? \$\endgroup\$ – Andy aka Dec 12 '19 at 8:43
  • \$\begingroup\$ @Andy aka thruster is a motor with propeller where thrust force is generated used in quadcopters and rov . Esc is electronic speed controller used with thruster . I wanna clamp high voltage for less time and low voltage for long time so thats work of tvs and varistor \$\endgroup\$ – Ahmed elmenshawie Dec 12 '19 at 9:32
  • \$\begingroup\$ @Chris Stratton system voltage is power supply 48 volt then 2 buck converters then arduino and thrusters ( motor with propeller ) . I wanna protect arduino , converters from surge current and clamp voltages \$\endgroup\$ – Ahmed elmenshawie Dec 12 '19 at 9:34
