What is the difference between a NEMA L14-30 plug (L14 type, 30 amps) and L10-30 plug (L10 type, 30 amps), electrically? With L10-30, one wire becomes neutral while the other one is hot and they change roles every half-cycle, so why does the L14-30 have a separate neutral?
I was looking for a converter for powering a dryer with a L10-30, but could not find that kind of device. I also want to know if it's possible to power other split-phase appliances in my house with an L14-30 plug on a generator.
Full reference for NEMA plug types is here (PDF).
closed as off topic by Leon Heller, Dave Tweed, Olin Lathrop, Brian Carlton, W5VO Nov 6 '12 at 4:34
Questions on Electrical Engineering Stack Exchange are expected to relate to electronics design within the scope defined by the community. Consider editing the question or leaving comments for improvement if you believe the question can be reworded to fit within the scope. Read more about reopening questions here. If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ We're just supposed to know what "L14-30" and "10-30P" are without any reference? I am voting to close as not a real question. Right now this question just does not have enough information to allow me to answer it. \$\endgroup\$ – Olin Lathrop Nov 3 '12 at 23:14
  • \$\begingroup\$ That's americans for you, they assume that stuff that is well-known in america is well-known by everyone. \$\endgroup\$ – Peter Green Oct 31 '17 at 17:31
As the Wikipedia article that you linked to points out, the L10-30 is a hot-hot-neutral, and L14-30 is hot-hot-neutral-ground.
What is the difference, electrically?
  • The L10-30 can't actually ground an appliance, since ground isn't available. It uses neutral instead, though that can differ from ground by several volts under normal circumstances, and can be as high as line voltage under certain failure modes.
  • The L10-30, doesn't provide a safe means for asymmetric line-to-neutral currents, since the such asymmetry will raise the "ground" potential in the end device (since it's really neutral, not ground).
  • The L14-30 will support asymmetric line-to-netural loads while maintaining a safe ground (via the separate neutral connection).
  • Because it is much safer to have a ground that you can count on to always be at a predictable potential vs. earth ground.
That depends on the generator, but yes, provided that the generator has separate overcurrent protection for each phase vs. neutral, you should be able to power split-phase appliances.
