I am trying to determine what this symbol is that looks like a circled capacitor and is labeled as "Z1" that I circled in blue below.
Here is the full schematic with this component being near the top left at the input.
This is the full schematic
In my search I found this question with a circled capacitor and a dot but I'm not sure if its the same. I also found websites saying Z is for zener diodes which this obviously is not or this website that says Z could be for a balun, general network, or phase shifter but I did not find circuit symbols that match this one when googling those.
  • \$\begingroup\$ circled capacitor and a dot - I don't see the dot. \$\endgroup\$
    Dec 13, 2019 at 13:56
    \$\begingroup\$ With a dot I would assume a neon/gas-dicharge tube. Without I would not know. (Neon tube without gas????) \$\endgroup\$
    – Oldfart
    Dec 13, 2019 at 14:07
    \$\begingroup\$ @Andyaka the dot is in the question in the link. For clarification mine does not have a dot which is why I don't think its the same as the one in the link. \$\endgroup\$
    – orange1234
    Dec 13, 2019 at 14:34
They are indeed varistors like others are (educatingly) guessing.
Varistors Z1 and Z2 have overvoltage protect function on the line input.
Source: http://www.pavouk.org/hw/en_atxps.html
You can find this source by googling on ATX power supply using the website on the schematic.
Search term: ATX POWER SUPPLY site:www.pavouk.org
It's likely an MOV (Metal Oxide Varistor) used for surge suppression. Context guides this answer - the schematic is from the late 1990's when this was a common use and it is across the hot/neutral lines and in the earth ground path.
The "Z" reference designator strongly suggests that it is some kind of voltage-clamping device. It could be anything from a spark gap to a gas-dicharge tube to a semiconductor device such as a MOV or TVS. What does the parts list (bill of materials) say about it?
    \$\begingroup\$ My guess from the symbol alone would be a gas discharge tube of some sort, since that's the closest to the symbol. \$\endgroup\$
    – Hearth
    Dec 13, 2019 at 13:53
  • \$\begingroup\$ I don't see a BOM but the website I got the schematic from is this hardwaresecrets.com/anatomy-of-switching-power-supplies/2 \$\endgroup\$
    – orange1234
    Dec 13, 2019 at 13:55
  • \$\begingroup\$ Well, since that site doesn't talk any further about that particular schematic -- the section on transient filtering uses a different schematic -- there's no way to know exactly what Z1 is. \$\endgroup\$
    – Dave Tweed
    Dec 13, 2019 at 13:59
