I know the theory but don't have much practice with this, so while I am experimenting with little success I ran into this question: what are the bad effects by violating the Absolute Maximum Ratings for a multivibrator build out of logic gates? Here is the relevant part of the schematics, an RC network combined with some logic gates, e.g. as in CD4011:
This is the basic schematic that you will see for a-stable and bi-stable multivibrators. Often you will see a big resistor between C and the input of G2, but because CMOS gates have virtually zero input current, that resistor does nothing and has zero volt.
Online example: https://www.electronics-tutorials.ws/sequential/seq_3.html schematic: https://www.electronics-tutorials.ws/wp-content/uploads/2018/05/sequential-seq10.gif
When the outputs of G1 and G3 are different, C will be charged and a voltage will be build over C. The voltage over C cannot exceed 5 V, assuming that the gates are powered with 5 V. According to the specs, e.g. https://www.ti.com/lit/ds/symlink/cd4011b.pdf , the output of the gates can be within 50 mV of the supply voltage, if "1", or ground, if "0". But let's be realistic, the idea is that G2 will switch at some point. The transition range is about 1.5 - 3.5 V, so C will be charged at least to 1.5 V when G2 switches over.
When G1 switches, its output changes with about 4.9 V. With 1.5 V on C, the input of G2 will then get a voltage of either 6.4 V or minus 1.4 V. With 3.5 V on C, those voltages are 8.4 or minus 3.4 V.
My point is that such input voltages are way out of spec. The Absolute Maximum Rating for inputs is 0.5 V above the power supply (Vdd), and 0.5 V below zero:
When designing something, you always try to stay within the manufacturer specs of the components. Specs often state that operating a component outside the absolute maximum ratings may affect reliability, which in clear text means that the component may become permanently defective, or "broken". There is no guarantee that it gets damaged after some seconds or days when the input is beyond abs max rating.
Because I see so many applications of RC networks with logic gates, I am really wondering if we should take those Abs Max Ratings serious.
Update:
Two commenters provided answers that made me understand how this issue works, thanks! I also drew a schematic, but don't want to present as an answer, hence this update. In real R-C applications there is an extra R2, and the logic gate has protection diodes that play an active role:
The idea is to make the timing depending on C1 and R1, so R2 should be significantly larger than R1. R1 should be at least 5 kOhm because the 4011 has a maximum of 1 mA output current. The input of the logic gate is high-ohmic because of the FET, if the input voltage is within 0 to 5 V. When the input voltage raises above power supply or lowers below zero because of G1 switching, one of the input protection diodes will be conducting. R2 must be large enough to limit the input current to 10 mA, just barely visible on my screenshot of the absolute maximum ratings, but this will always be the case because R2 >> R1 and R1 > 5 kOhm.
The answer is that the Absolute Maximum Ratings are NOT exceeded because of the R-C network. Even with R2 of zero ohm, because G1 cannot deliver an output greater than 10 mA, but then the time constant is not just R1 times C1.
