datasheet: http://www.ti.com/lit/ds/symlink/ne5532.pdf
I saw in most opAmps this rate was given as V/us, for example, for LM741 it was 0.5V/us. Is this 9V/ms a typing error? Because if it is not, then this NE5532 is way slower than the LM741 which is a very ancient opAmp(I have been told so many times).
    \$\begingroup\$ Valid question, not sure why someone downvoted it. Typos in datasheets are very annoying sometimes. \$\endgroup\$
    – Hearth
    Dec 16, 2019 at 20:56
    \$\begingroup\$ half a century ago microfarads were printed on parts as MFD as well \$\endgroup\$ Dec 16, 2019 at 21:11
  • \$\begingroup\$ @Hearth I will try to send a feedback email about this to TI. edit: I cannot find a way to do that, it should not be that hard. \$\endgroup\$
    – muyustan
    Dec 16, 2019 at 22:37
  • \$\begingroup\$ Argument: typos that can be resolved by looking for the authorative parts in a datasheet (in this case, the obvious table, the short description and the part website) don't make great questions, though, @Hearth. \$\endgroup\$ Dec 16, 2019 at 22:51
It is a typo. If you look in the specs section you'll see it specified as V/μs.
Also in the features section: High Slew Rate: 9 V/μs Typ
  • \$\begingroup\$ ok, I just wanted to be sure, thanks. \$\endgroup\$
    – muyustan
    Dec 16, 2019 at 20:37
