I have designed a PCB using Autodesk Eagle.
After I routing the PC and check for errors from Tools -> Errors, there are lot of airwires (31) like below. But, I couldn't find any airwire.
How to solve this problem?
  • \$\begingroup\$ There's a ulp for that. Well, a 3rd party one. \$\endgroup\$ – Chris Stratton Dec 17 '19 at 5:36
  • \$\begingroup\$ Do you have layer 19 hidden? \$\endgroup\$ – Bruce Abbott Dec 17 '19 at 6:12
  • \$\begingroup\$ @BruceAbbott No. Its visible. \$\endgroup\$ – user_fs10 Dec 17 '19 at 6:19
  • \$\begingroup\$ @ChrisStratton Sorry. I didn't get it. \$\endgroup\$ – user_fs10 Dec 17 '19 at 6:20
    \$\begingroup\$ Try the hints given here: rerun DRC, set the airwire colour to bright magenta, turn all layers off except the airwire layers \$\endgroup\$ – Huisman Dec 17 '19 at 7:16
After rerunning DRC problem is solved as @Huisman mentioned.
If you just select Tools -> Errors, It shows previous errors without updating current status.
Use Tools -> DRC... and click on the Check button to update the errors.
