What would cause a USB device to draw drastically different amounts of current, but still function properly?
Background & Research:
- I purchased a Playstation 2 Graphics port->HDMI converter (like this one) that requires external power via micro-USB port, claiming to require a 1A rated source.
- Using a USB Tester, I found the typical current draw to power the HDMI converter from a USB wall adapter to be .25A (250mA) (~1/4 of the manufacturer recommendation).
- The USB specs for my Playstation 2 (Model SCPH-30001) is supposed to be USB 1.1 with a maximum output current of .1A (100mA).
- I tried plugging in the HDMI converter to the Playstation 2 for a few seconds at a time to see if it would function correctly, and it did, though it only drew about 0.01A (10mA). So...
Questions:
1. What is going on here?
The HDMI Converter pulls 250mA at 5.05V from the power brick, but only 10mA at 5.05V from the 100mA-rated USB 1.1 socket. It seems to work just fine from either, displaying HDMI signal on the TV.
The HDMI Converter does not seems like it would require a lot of power, as it should only need to provide power for HDMI communication (rated minimum: .055A) and powering the tiny chip. Why would it pull so much more from the wall adapter?
2. Is this safe?
Am I damaging one or both of the devices by powering the converter from the Playstation 2?
I DO NOT want to harm the Playstation 2, as I have burnt out USB ports by overloading them before. (But I CAN afford to fry the HDMI converter for experimentation's sake.)
