I'm looking for a type of potentiometer (ideally about 500k) that has a feelable click switch at both ends. I have only found ones with a single on/off switch. What's the term I need to look for?
1 Answer
The key words you should look for are “modular potentiometer”.
You stack various options of parts to build a pot to meet your requirements, and maybe that will be an available combination. I notice some (eg. Series 389 from State) specify only one switch per shaft maximum so you still may not find what you need.
