What's the difference between this two methods of "tap switching"? do they work the same?
    \$\begingroup\$ No they don't work the same. \$\endgroup\$ – Andy aka Dec 18 '19 at 10:06
No, the circuits are not the same.
I removed the "fluff" (the rectifiers are irrelevant) and added labels.
The top circuit can output 4 different voltages if the voltages across the separate windings are all different.
The bottom circuit can only output 3 different voltages, when S2b is in the "C" position, switch S2a does nothing.
    \$\begingroup\$ +1 Even if A:B is 5V, B:C is 5V, C:D is 10V , then you can get 5, 10, 15, or 20V from the top circuit, but only 10, 10, 15, 20 from the bottom circuit. \$\endgroup\$ – Spehro Pefhany Dec 18 '19 at 10:55
