In order to achieve this I was going to have the following setup:
Base Station
  • Raspberry Pi
  • Xbee 2mw
Led Station
My main questions are:
  • Is it possible to use the xbee to drive the tri-color driver without needed a microcontroller, arduino or raspberrypi on the led station side?
  • If I want to expand this in the future, can I add more LED and drivers combinations to be driven by the same xbee?
I'm new to this so any help or advice would be appreciated. Thank you!
  • \$\begingroup\$ What does the xbee output? What does the LED driver chip require as input? \$\endgroup\$
    – pjc50
    Commented Nov 5, 2012 at 14:45
Looking at the Shiftbrite LED module page and xBee datasheet, it would seem you can do this without a microcontroller.
The Shiftbrite LED module uses 4 lines (3 if enable always active) which are:
Data, Clock, Latch and Enable (both input and output pins, so 8 pins in total)
This means modules can be chained together easily, so you can add more Shiftbrite LED modules later on if desired.
The xBee has 8 pins which can be used as digital I/Os, and configured in "virtual wire" mode, where whatever logic level appears at the Tx input pin will be output on the corresponding Rx output pin.
So, with a bit of reading to setup the xBee for virtual wire mode, you should be able to write your code as if the LED module was connected directly to the R-Pi
