I have a 3x1.5V battery pack (AA alkaline). It's fresh and with no load sits at 4.8/4.9V.
In parallel, I have 3 LEDs, each with their own resistor. That works fine..
I can also switch in a 5V laser diode module. That also works fine..
But if I attach everything at the same time, the laser diode module is lit, but not the LEDs.
I suspect/hope this is some fairly straightforward concept - but if the battery is sitting as it is, everything works well and these are fairly low-power devices, all connected in parallel - I don't understand it.
Can anyone guide me in the right direction?
