I've been making my own simple FM radio. I know it's not quite appropriate to make this stuff on breadboard, but if it works, I'll move in on the board and solder it. I wanted to ask why my radio is not picking up any signals.
At first I thought of having a very small antenna for this purpose. I don't know if it is enough, but I don't think so. Then I realised I also might have connected my circuit wrongly. Or the variable capacitor. I've been thinking a lot how I am supposed to connect it properly. Because I have no idea. Can anyone tell me? And is there a way I could vary my variable capacitor with a metal screwdriver? I don't have any plastic ones..
Here's the schematic of the circuit:
Here is the screen of my variable capacitor:
And the way it's all connected on breadboard could be seen here: enter image description here
I filtered high-frequency noise using low-pass filter and I only heard some small humming noise there. I wasn't sure if it was talking or not.. After I used my screwdriver, I didn't hear anything, everything was quiet.
Help me out with this project, please.
  • \$\begingroup\$ Hmmm! You're a bit short of FM receive components. Where did you get that schematic from? What were you told it would do? \$\endgroup\$ – Neil_UK Dec 21 '19 at 9:49
  • \$\begingroup\$ I found it on the youtube. To be precise, on GreatScott's channel. Crude FM Radio. \$\endgroup\$ – MerryGR Dec 21 '19 at 9:58
  • \$\begingroup\$ Do I need more transistor stages or what? \$\endgroup\$ – MerryGR Dec 21 '19 at 10:00
Your "FM receiver" is at best an AM receiver.
It should be possible to build an AM receiver on a breadboard. Commercial broadcast AM stations in the USA are on frequencies from 560 kilohertz to 1.695 megahertz. That's low enough that you could expect the circuit to work on a breadboard.
Commercial FM broadcast in the USA is from 88 megahertz to 108 megahertz. That is much too high to run on a breadboard. The individual pin rows act like inductors at those frequencies, and the rows act like there are capacitors connecting them. (That is, pins in a row that are connected together will act like an open circuit at high frequencies, and adjacent rows will act like they are shorted together.)
88MHz is just too high.
Your circuit doesn't resemble any typical AM receiver that I've ever seen, nor does it resemble an FM receiver.
Your best bet is to buy a kit (one that has a good set of instructions and also explains the theory behind radio and the receiving circuit.)
Alternatively, find a project description that includes a good explanation and a parts list. Purchase exactly the parts recommended by the author.
In either case, follow the instructions exactly. Many AM receiver circuits are simple (few components, few connections) to assemble but complicated to use (setup, tuning, antenna placement, etc.)
If this is the video you followed, then it is probable that it will work if properly built and tuned. That doesn't mean that it will be easy. It also doesn't mean you can build it on a breadboard.
That circuit will be twitchy (very sensitive to the presence of other objects close by) and very sensitive to stray capacitance and inductance.
The capacitors and inductors used in the circuit have values close to the capacitance between rows on the breadboard and the inductance in the rows. It will be pretty much impossible to tune it to anywhere close to the needed frequency - if it can work at all. And, that's ignoring the inductance of your long wires.
If you want to build that circuit, then you absolutely must build it as shown and described. That means right down to the size of the perfboard and the placement of the components. You will have to solder it together.
No other way of building that circuit will work properly. It is not a proper FM demodulator, and it does not use a typical RF receiver or amplifier.
The coil you made is completely mashed out of shape. It won't have anywhere close to its intended inductance.
My first job in the field of electronics was tuning the low pass filter on the output of 25watt radio transmitters. They were "tuned" by stretching (or pushing back together) the coils in the filter. The coils used were about the size of the one needed for the circuit you are trying to build. A coil as far out of shape as yours is would have messed up the tuning to the point that it would have been easier to replace it than to tune it.
| improve this answer | |
  • \$\begingroup\$ Thank you for your long, long text on why it's not working. I appriciate your time.. I don't think my country uses some AM stations anymore. They're all mostly FM. Can I build my own AM transmitter for at least 1 or 2 metres? Just a project to learn from. I know how AM should look like. And the receiver is pretty simple there. So for example, I can play music and trasmit it and then receive it. But I think this wouldn't work properly on breadboard as well, right? \$\endgroup\$ – MerryGR Dec 21 '19 at 10:56
  • \$\begingroup\$ Like I said, given the source, the circuit probably is an FM receiver of sorts and would probably work if you build it exactly like it needs to be. AM transmitters can be built easily, as well as AM receivers. There projects online, as well as kits. I'd start with kits. \$\endgroup\$ – JRE Dec 21 '19 at 11:02
  • \$\begingroup\$ Okay, thank you! \$\endgroup\$ – MerryGR Dec 21 '19 at 11:15
The two transistors in this circuit are very likely intended to be a regenerative detector. Component values of L1 (207nH) and CV (8-28 pF) are chosen to resonate somewhere in the FM broadcast band (88 MHz -to- 108 MHz here).
The circuit is intended to oscillate, or at least approach oscillation. When it oscillates, you should be able to hear its weakly-radiating signal on a nearby FM radio, tuned to the same frequency. CV is a variable capacitor so that frequency can be adjusted. Note that the short antenna wire (no more than about 30cm) also affects frequency.
The capacitor CV looks similar to the one shown below. The rotor with the screwdriver adjustment is connected to one of the two terminals. This connection should go to the ground side of the circuit, so that when a tool is used to adjust, capacitance is affected the least. Even so, frequency will likely change.
trimmer capacitor
@JRE suggests a path to potentially successful construction.
The audio portion of this circuit involving LM386 chip can be built on a breadboard. I would add a 100uF capacitor directly from pin 6 to pin 4, taking care to put the "+" side on pin 6. The two transistors and associated components don't belong on the same breadboard...dead-bug construction might be a good approach.
These regenerative receivers can work surprisingly well, but are notoriously difficult to build properly.
  • Frequency can vary widely, depending on short wiring paths, antenna length
  • Regenerative receivers work best when barely oscillating, or almost oscillating. Adjusting components to achieve this operating point is very difficult. (This receiver has no control of its operating point).
