I am trying to make a very simple module in System Verilog that receives a short pulse as an input, and returns as an output a pulse which is twice wider. For example, if the input is a 1ns pulse, then I want the output to be 2ns pulse. A delayed output would be even better.
I thought of making a frequency divider, but that won't help here, since frequency divider works with clocks, which rise and fall all the time, in contrast to a pulse, which will rise only once.
Thank you!
    \$\begingroup\$ Behavioral or for real? Also I am not yet sure what you mean with "A delayed output would be even better". \$\endgroup\$
    – Oldfart
    Commented Dec 21, 2019 at 15:01
  • \$\begingroup\$ A very simple module won’t be able to do what you want with any degree of accuracy or repeatability. \$\endgroup\$
    Commented Dec 21, 2019 at 15:45
As we have several people who say that it can't be done here is a behavioral solution :-) Note that in real hardware it can't be done this way.
module pulse_double(
   input      pulse,
   output reg double_pulse
time time_rise,time_elapsed;
   always @(posedge pulse)
      time_rise = $time;
   always @(negedge pulse)
   begin
     time_elapsed = $time - time_rise;
     double_pulse <= 1'b1;
     double_pulse <= #(2*time_elapsed) 1'b0;
  end
endmodule
module pulse_double_test;
integer loop;
reg  pulse_in;
wire pulse_out;
   pulse_double pulse_double_inst(
    .pulse(pulse_in),
    .double_pulse(pulse_out)
  initial
  begin
     for (loop=0; loop<10; loop=loop+1)
     begin
        pulse_in <= 1'b1;
        #(($random & 32'h07)+32'h02); // width between 2 and 9
        pulse_in <= 1'b0;
        #20;
     end
  end
endmodule
With the waveform:
This is a simple solution which works for non-overlapping input/output pulses. If input pulses can overlap with the output you have to define what behavior is wanted and then adapt the code accordingly.
As oldfart correctly points out: This answer applies to verilog meant to actually define hardware only; for simulation models, see his answer!
That's not among the abilities of verilog, as far as I can tell; since this is not a logical or clocked thing that you want, it's impossible to represent it in verilog.
However, let's rephrase:
If the input is a pulse that lasts for N clock cycles, then I want the output to be 2N clock cycles long.
Then it's really just counters: one increasing a "must still be emitted count" by one per clock cycle as long as the input is high. You'd add minimal logic: The output is high as long as the input is high OR the counter > 0. Also, for as long as the input is low, and counter > 0, decrease counter by 1.
Done! All you need is clock that is at least as fast as the shortest pulse you want to deal with. But that's kind of a given, since this really is digital logic, and not analog circuitry.
    \$\begingroup\$ Marcus, the first is also not problem if the code is behavioral. That is why I asked "Behavioral or for real?" \$\endgroup\$
    – Oldfart
    Commented Dec 21, 2019 at 15:56
  • \$\begingroup\$ @Oldfart you're right, and I added a bit of prologue :) \$\endgroup\$ Commented Dec 21, 2019 at 17:02
