I have another question regarding some VHDL. I am trying to create a pulse of 5 ms output (in my code a_full), however, I am struggling to find any information on how to generate this, basically I want a full pulse of 5 ms when the count reaches 12 and for that to reset the count.
Can anyone please point me in the right direction?
I have added my code for reference.
-- Library Decleration
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.numeric_std.all;
--entity declaration
entity egg_sorter is
    port (  Reset       : in std_logic;
        Egg_Size    : in integer range 0 to 7;
        Egg_available   : in std_logic;
        A_Count     : out integer range 0 to 12;
        A_Full      : out bit;
        b_Count     : out integer range 0 to 12;
        b_Full      : out bit;
        c_Count     : out integer range 0 to 6;
        c_Full      : out bit;
        d_Count     : out integer range 0 to 6;
        d_Full      : out bit
end entity;
-- architecture
architecture behavioral of egg_sorter is
-- signal declerations due to being outputs and VHDL not being able to read outputs
signal A_Count_Value : integer range 0 to 12;
signal A_Full_S : bit;
signal b_Count_Value : integer range 0 to 12;
signal b_Full_S : bit;
signal c_Count_Value : integer range 0 to 6;
signal c_Full_S : bit;
signal d_Count_Value : integer range 0 to 6;
signal d_Full_S : bit;
begin
    -- this is the count process for size A eggs
Process (Reset, Egg_Size, Egg_available)
    Begin
        if reset <= '1' then
         b_count_value <= 0;
        end if;
            case egg_size is
                when  0 to 2 =>
                    if rising_edge(egg_available) then
                        if a_count_value < 12 then
                            A_Count_value <= A_Count_value + 1;
                        elsif a_count_value <= 12 then
                            a_full_s <= '1';
                            a_count_value <= 0;
                        end if;
                    else a_count_value <= a_count_value;
                    end if;
                    b_count_value <= b_count_value;
                    c_count_value <= c_count_value;
                    d_count_value <= d_count_value;
                when  3 | 4 =>
                        if b_count_value < 12 then
                            b_Count_value <= b_Count_value + 1;
                        elsif b_count_value <= 12 then
                            b_full_s <= '1';
                        end if;
                    else b_count_value <= b_count_value;
                    end if;
                when 5 | 6 =>
                        if c_count_value < 6 then
                            c_Count_value <= c_Count_value + 1;
                        elsif c_count_value <= 6 then
                            c_full_s <= '1';
                        end if;
                    else c_count_value <= c_count_value;
                    end if;
                when 7 =>
                        if d_count_value < 6 then
                            d_Count_value <= d_Count_value + 1;
                        elsif d_count_value <= 6 then
                            d_full_s <= '1';
                        end if;
                    else d_count_value <= d_count_value;
                    end if;
            end case;
    end process;
A_Count <= A_Count_Value; -- this puts my signal value to my output
a_full <= a_full_s;
b_Count <= b_Count_Value; -- this puts my signal value to my output
b_full <= b_full_s;
c_Count <= c_Count_Value; -- this puts my signal value to my output
c_full <= c_full_s;
d_Count <= d_Count_Value; -- this puts my signal value to my output
d_full <= d_full_s;
end behavioral;
    \$\begingroup\$ howcome you don't have a clock? \$\endgroup\$
    – stanri
    Jan 19, 2020 at 16:44
I have not tried this yet, but how about something like:
d_full_s <= '1';
wait for 5 ms;
d_full_s <= '0';
You may also need to set all of the strobes to zero early near the beginning as part of your reset, to prevent erroneous values.
  • 4
    \$\begingroup\$ As Adam Bromby is a new member it's advisable to update your answer to indicate that it only works for simulations. Additionaly you could show a synthesizable solution with a counter. \$\endgroup\$
    – Kitana
    Dec 28, 2019 at 19:23
