38
I have a box that I made for my niece, which allows her to exchange voice messages with me. It is powered by a Raspberry Pi and features two buttons, a LED, a microphone and a speaker.
the box
Now, for Christmas I want my niece to be able to exchange these voice messages with various friends (4, 8 or 16) and relatives by plugging in a hardware token to the device, featuring a picture of that person.
I am now looking for the most simple way to add this functionality.
  • Preferably using a 3.5mm jack socket because they are readily available from used devices / headphones
  • Preferable a passive device (Capacitors + Resistors)
  • Preferably by attaching it directly to the Raspberry Pi
  • Preferably without using a AD-converter, since the Raspberry Pi does not have this built-in.
  • Easy to use by a 3-year-old
So using a 3.5 mm plug with 3 pins I could add attach power to one pin and either connect or disconnect the other two from that pin, which would leave me with two bits, resulting in 4 people (in addition to me as the default, if the socket provides a switch when a plug is inserted).
If I had an analog-digital converter I could add a voltage-divider to the three pins and use the voltage as an indicator. However, the Raspberry Pi does not have that built-in so I am looking for a smart way to achieve this using one of the GPIO pins.
relatives-plug
  • 14
    \$\begingroup\$ That is a very nice toy that you built! \$\endgroup\$ Commented Dec 22, 2019 at 11:36
  • 13
    \$\begingroup\$ Thanks @MarcusMüller. It's fun to have my niece chat with me like this. I plan on uploading the source and instructions to github and I will possibly post that here then. Happy holidays ;-) \$\endgroup\$
    – Besi
    Commented Dec 22, 2019 at 11:38
  • 8
    \$\begingroup\$ Whatever you do, make sure that you don't fry any other devices with the 3.5mm jacks that might get plugged in there! (Headphones, mics, etc) \$\endgroup\$
    – flawr
    Commented Dec 22, 2019 at 22:37
    \$\begingroup\$ @flawr very good point. The fact that I am using parasitic power should take care of this issue. The chip will pull the pulled up voltage down to GND and the GPIO input is high impedance. And all that can happen in that scenario is that the GPIO4 is pulled down to ground. \$\endgroup\$
    – Besi
    Commented Dec 22, 2019 at 22:47
    \$\begingroup\$ That's why the passive R is preferred. effective. simple, passive. \$\endgroup\$ Commented Dec 23, 2019 at 3:12
8 Answers 8
49
+100
Use 1-wire bus and any 1-wire chip inside the button. I wrote "any", because each 1-wire chip has its own, unique hardware address, so all that you need on RPi side is checking that the chip was detected, for example using bash command:
ls /sys/bus/w1/devices/
and checking it's output for existence of subdirectory named exactly as this hardware address.
On RPi HW side you need only connect additional jack socket to proper I/O pins (GND + DATA). There is no need to use any power connection here, so it looks to be safest for RPi than similar solution, which uses I2C (I2C needs to have dedicated power line, what makes risk of damage RPi in case of short-circuit).
EDIT: For reliable work you should add the pull-up resistor 4.7kOhm between DATA line and Vcc (3.3V).
You can use most popular and cheap DS18B20 chip, which additionaly provides possibility to measure the room temperature ;), or DS2401, which additionaly provides unique serial number.
  • \$\begingroup\$ This is very elegant. Thanks for sharing this! \$\endgroup\$
    – Besi
    Commented Dec 22, 2019 at 11:30
    \$\begingroup\$ I found a german tutorial a tutorial which explains how to setup the 1-wire chips: tutorials-raspberrypi.de/… \$\endgroup\$
    – Besi
    Commented Dec 22, 2019 at 11:57
    \$\begingroup\$ Yes, it can be omitted - in that case this pin should be connected to ground. So, pins 1 + 3 = ground, pin 2 = data. You need to add 4.7kOhm pull-up resistor between DATA line and Vcc (3.3V). See figure 6 here: datasheets.maximintegrated.com/en/ds/DS18B20.pdf \$\endgroup\$ Commented Dec 22, 2019 at 12:53
    \$\begingroup\$ Of course, but it can be simply protected with diodes. Additionaly, the jack socket design simply protects against this - GND will be connected as the first always. \$\endgroup\$ Commented Dec 23, 2019 at 12:33
    \$\begingroup\$ @VillageTech I did implement your solution and document my steps. See my answer below. Thanks and have a lovely 2020 \$\endgroup\$
    – Besi
    Commented Jan 1, 2020 at 21:53
8
I would make each "token" an I2C device. Using a tip-ring-ring-shank style jack would give you 4 conductors -- ground, power, data, and clock. Each token would need to have it's own I2C address, and you would write a function that sniffs out devices on an I2C bus.
    \$\begingroup\$ If you follow the standard pinout for a headset plug - Tip=speaker, Ring1=speaker, Ring2=ground, Sleeve=power+mic - then there might not be any damage if it gets confused for one. (Note: power is a current source, not a voltage source. This allows the mic signal to exist as an AC-coupled voltage, just like the speakers.) \$\endgroup\$
    – AaronD
    Commented Dec 22, 2019 at 17:49
  • \$\begingroup\$ Same as with the accepted answer. No offense, but -1: This will likely be vulnerable to static electricity. \$\endgroup\$
    – Charlie
    Commented Dec 23, 2019 at 12:30
  • 7
    \$\begingroup\$ @Charlie, just like every digital circuit in the world. \$\endgroup\$ Commented Dec 23, 2019 at 12:33
  • \$\begingroup\$ @Scott, Practically speaking, yes. Technically, only really CMOS, so, again, practically yes. It's more about the fact that a TRS jack exposes the leads. How many times will this be pulled in and out of polyester coat pockets over the winter? \$\endgroup\$
    – Charlie
    Commented Dec 23, 2019 at 13:00
    \$\begingroup\$ TRS is certainly a concern. It's not the connector I would choose, not because of static, but more because of all the inappropriate make/breaks during insertion. Like many circuits, this would require protection. \$\endgroup\$ Commented Dec 23, 2019 at 13:57
6
This can be done with a set of resistors and capacitor in parallel, each pair with a different RC product. You would turn the gpio output high for a sufficient time, then turn it to an input and measure how long it takes for the cap to discharge. With time constants ranging from microseconds to milliseconds possible , you can distinguish any number of people.
To be crystal clear. I do not hate the 1-wire token idea. I actually like it. Using 1-wire this way is exactly the kind of thing the 1-wire bus was made for. My concern is that the project is toy grade; low security/budget. When you then add the durability considerations, it becomes clear that there may be desire for other options that don't involve specialized chips. Which brings up the following.
As others have said, the almost optimum answer is to use RC time delay. The only component token side would be a capacitor.
Why? Because RC tokens ...
  • are not vulnerable to ESD. (Edit: If we are being honest and practical)
  • can use just two wires.
  • will be dirt cheap and simple.
  • have plenty room for 8+ people.
For the Pi side electronics, you just need two GPIO pins; a charging pin, and a sensing pin. You will also want/need a fast charging circuit, which I'll explain after the graphic.
The fast charging circuit bypasses the timing resistor with a much smaller resistor. This allows the capacitor in the token to charge nearly instantly (well, as far as the users will see any way). It also makes it so the sense pin does not see the charging pin directly. Instead, it will strictly see the capacitors voltage. Values are not critical, however, the diode really needs to be a Schottky/small signal diode, or it will cut a lot off the top of the 3.3v. This could also be replaced with a transistor to 5v, but the input pin may need to be protected.
After that, it's all code, which is pretty trivial as well.
(Note: Came up with this on the spot. It's totally untested. Standard disclaimers apply; Tread at your own peril, adjust to taste, etc. etc.)
import RPi.GPIO as GPIO
import time
#Setup some pins
GPIO.setup(<charging_pin>, GPIO.OUT)
GPIO.setup(<sensing_pin>, GPIO.IN)
# Set "charging" pin to 3.3v
GPIO.output(<charging_pin>,TRUE)
# Wait some time for the capacitor to be fully charged
time.sleep(1.0)
# Set the charging pin to 0v
GPIO.output(<charging_pin>,FALSE)
#count how long the sense pin stays high
counter=0
while GPIO.input(<sensing_pin>) == GPIO.HIGH:
    counter += 1
    time.sleep(0.01)
# Finally our counter is going to have a value proportional to the RC
# time delay of our token. Window match it to bounds, and we're golden.
if (counter > a) and (counter < b):
    print "Is person X"
if (counter > b) and (counter < c):
    print "Is person Y"
Lastly (and only as an aside/after thought) this same thing would not be too terrible repurposed as a capacitor tester/meter, as that's basically all we are doing here.
Criticism
This is so much harder than a 1-wire solution. The 1-wire solution is just plug-and-play. RC will have a bunch of wiring and soldering and so on. The Pi side circuit alone will be so complex that the total cost will be higher than just using 1-wire.
Not at all true.
I think I have shown above how trivial the RC solution is; ~13 lines of code, 3 components Pi side, and 1 capacitor per person. Pretty simple actually.
1-wire is, admittedly, equally fairly trivial to setup, but that is because you are buying your way out. Every 1-wire token adds another $0.5 chip, where as every RC token added is just a $0.01 capacitor.
Almost as simple, but a fraction of the cost. Pretty clear who the winner is here.
Your idea is vulnerable to static. The Raspberry Pi is vulnerable to static. This is vulnerable to static. That is vulnerable to static. Your dog is vulnerable to static. etc. etc. etc.
News flash! Everything is technically vulnerable to static/ESD, Even you! Don't believe me? Go stand out in an open field with an umbrella and prove me right. (PS. don't do this)
However, if we are not being smart @$$, then we have obvious lines that we draw. The commonsense spot is at CMOS IC's, since that is what - in a very real and practical sense - is actually vulnerable to static. The fun thing is we can remove this problem entirely for the token by not using an IC AT ALL!
Passives are just about as easy for the presented task, and more robust against ESD. period. This is why one may want to reconsider the other methods.
Now, of course, the Pi is always going to be vulnerable to static electricity, no way around that unless you remove the Pi. Of course, that's not practical either. So, the best we can do is do what everyone else does with those lemons. First, we put the socket on the Pi side with a proper guard ring to ground. Second, we can go nuts with TVS diodes and so on. Bottom line here...
We only have to ESD protect one(1) device now, so go nuts if you want!
Simple passives are not secure. They are easy to fake/copy/hack/etc.
(-_-) ... this is a kids toy FFS ... why are we bringing information security into this? Even so, do you actually think 1-wire hardware addresses, (or even worse, SPI/I2C addresses) are a good mechanism for enforcing security? Really? Are you serious!?
OK, how about this then... take that idea to security.SE. and see what they say. (Protip: Bring bandages with you, you'll get torn a new one.)
No. The ONLY time 1-wire is secure, is if you are using an actual secure token/authenticator [1]. Then it can be nation state secure... other than the fact that the attacker for sure has physical access to the authenticating device...
Security is a non issue here, it's totally off topic.
Edit: Broke the rest out into it's own answer, as that is what it was; a different answer.
    \$\begingroup\$ @Besi: (a) No problem. (b) Understood. (c) Yes, Bluetooth would have problems with ambiguity. Mostly because Bluetooth's range would work against you. The "poor man's RFID" I mention would not have this problem, however, as you would have to have the token right on a "detection area" for it to even be seen. Basically, it would be like "Tap and go" contact-less payment systems, (Google Near Field Communication) Another way of thinking of it is like having a metal detector in the RPi, and different metals in your token. Only, we replace the different metal with tuned electromagnetic coils. \$\endgroup\$
    – Charlie
    Commented Dec 24, 2019 at 6:30
    \$\begingroup\$ That paper disproves your own implied assertion, though. If you look at the figures on page 2, it clearly shows that only very small thin film SMD resistors are remotely vulnerable to ESD. Thick film SMD resistors changed by less than 200k ppm after 4500v ESD events, and foil resistors by a non-measurable amount. It doesn't even get into through hole resistors, as that would be comically off narrative. \$\endgroup\$
    – Charlie
    Commented Dec 25, 2019 at 3:26
    \$\begingroup\$ Or, more succinctly: By default, CMOS is vulnerable to ESD, passives are not. period. The only RC solutions that could be even remotely vulnerable to ESD would have to be contrived that way. On the other hand ANY 1-wire solution would be vulnerable by default, and would have to be "patched" to be safe. Any counter argument saying otherwise is very much like the security counter argument; a lot of hand waving and grasping at straws. \$\endgroup\$
    – Charlie
    Commented Dec 25, 2019 at 3:34
    \$\begingroup\$ How about the accuracy of time.sleep(x), which is guaranteed to sleep for at least x, but could be considerably more if Raspbian decided to do something else? I think this solution is much better suited to a microcontroller using a hardware counter/timer than a Pi. \$\endgroup\$ Commented Dec 26, 2019 at 20:06
    \$\begingroup\$ Perfectly valid solution.(+1) Built-in 2stage R-diode ESD protection can be improved with additional 10k series res. then choose target 100k<R<10M \$\endgroup\$ Commented Jan 2, 2020 at 2:40
This is how I did finally implement the fabulous approach outlined by VillageTech.
Hardware
Wiring
The default pin for Onewire devices on the Pi is GPIO 4. So I wired GND to the sleeve of the plug and connected the tip to the mentioned GPIO pin.
hardware
A token
All I need for a token is the DS18B20 chip and a 3.5mm Jack. Then solder the GND and VCC pin of the chip together and connect it to the sleeve. Add some head-shrink tubing to the middle pin to prevent shorts and connect it to the tip of the jack.
Both jacks work the ones with two rings and the one with just the tip.
token
Pull up resistor
I did decide not to use an external pull up resistor, since the Pi has internal Pull up resistors.
Let's not fry headphones
As flawr correctly pointed out is the fact that if it looks like a 3.5mm audio jack people might be tempted to insert headphones.
As long as we're using parasitic power, where only a ground wire and a high impedance GPIO output is exposed to the socket, we should be safe, since we don't have a VDD line that might create a short circuit through the low resistance of the headphones.
Configuration
Add the following line to /boot/config.txt:
dtoverlay=w1-gpio
There are more options. You can find more in the /boot/overlays/README of your Pi.
Some sources suggested to add the two modules w1-gpio and w1_therm to /etc/modules, however I found out that the device-tree overlay entry in the boot/config.txt was sufficient for my purposes.
Now reboot the device.
Add a pullup via software in python:
GPIO_PIN_NUMBER=14
GPIO.setmode(GPIO.BCM)
GPIO.setup(GPIO_PIN_NUMBER, GPIO.IN, pull_up_down=GPIO.PUD_UP)
As soon as I created this pull up I could detect the tokens in /sys/bus/w1/devices/ with the 28 prefix in another terminal window:
$ ls /sys/bus/w1/devices/
28-00000aabbccd  w1_bus_master1
After 10 seconds or so the entries in devices would disappear. I had to create the following configuration, so that the devices would disappear after a second or so:
sudo nano /etc/modprobe.d/w1.conf
Now add the contents to the file and reboot the device again:
options wire timeout=1 slave_ttl=1
In my setup this file did not exist previously.
Software
I did create a python class that would look for changes in the file system and tell me if a new token was connected or if all tokens were disconnected.
import os
import thread
import time
from datetime import datetime, timedelta
class W1Service(object):
    __instance = None
    def __new__(cls):
        # Singleton initializer
        if W1Service.__instance is None:
            W1Service.__instance = object.__new__(cls)
        return W1Service.__instance
    on_all_token_removed = None
    on_token_added = None
    is_scanning = False
    def start_scan(self, delay=10):
        return thread.start_new_thread(self.scan, (delay,))
    def scan(self, delay=10):
        W1Service.is_scanning = True
        last_token = None
        current_token = ''
        current_token_timestamp = datetime.now() - timedelta(days=1)
        while W1Service.is_scanning:
            file = open('/sys/devices/w1_bus_master1/w1_master_slaves')
            all_tokens = file.readlines()
            file.close()
            no_token_attached = len(all_tokens) == 0 or 'not found.\n' in all_tokens
            if no_token_attached and self.on_all_token_removed and current_token != last_token:
                self.on_all_token_removed()
                current_token = None
                last_token = None
            for line in all_tokens:
                current_token = line.split("\n")[0]
                time_diff = datetime.now() - current_token_timestamp
                if self.on_token_added and last_token != current_token and time_diff.seconds >= 3:
                    # Test if the token is still attached
                    if os.path.exists('/sys/bus/w1/devices/' + current_token + '/w1_slave'):
                        self.on_token_added(current_token)
                        last_token = current_token
                    else:
                else:
            time.sleep(delay)
    def stop_scan(self):
        W1Service.is_scanning = False
Now using the created service is quite simple:
import time
import w1_service
def token_added(token):
    print("Connected %s" % token)
def all_token_removed():
    print('All tokens were removed')
service = w1_service.W1Service()
service.on_token_added = token_added
service.on_all_token_removed = all_token_removed
service.start_scan(0)
while True:
    # The scan runs in a seperate thread
    time.sleep(1)
This will produce the following output when inserting different tokens
Connected 28-00000aabbccd
Connected 28-00000ffddeea
Connected 28-00000bbddaa1
Please note that my code accounts for the fact that in my setup only one token can be added at a time. So only the newest token is interesting for me. If multiple tokens should be added, which the onewire protocol supports nicely, the code would have to be updated.
Application
Now whenever a token is inserted it is matched to a person that my nice can then send messages and receive messages from
application
Notes and other considerations
The Onewire tokens could in theory be added in parallel which would offer new capabilities like group chat or the like. So you could connect ten tokens on a single GPIO.
I also like the approach with the passive R/C approach, which is very pragmatic and simple to set up as well. I might try this out in another project. However, a friend had some
I did consider adding iBeacons as tokens but then I would have to account for different RSSI of the tokens and it would not be 100% clear which token was active at any given time.
A friend was suggesting to to add a card reader and use old 1GB photo SD cards which could have the picture stuck on the front. The card could contain all the information about the person plus a personalised greeting or the like. The same would work with old USB-Sticks as tokens.
It was tremendous fun to implement this and to see how much interest my question stirred in people. I thank you guys all and wish you a lovely 0x1414 (=2020) :-)
    \$\begingroup\$ Fantastic work and thanks for reporting back. +1. I have no regrets. It was fun to help with this, and you got a result that works. That's the best we can hope for. \$\endgroup\$
    – Charlie
    Commented Jan 3, 2020 at 17:36
TL;DR: poor man's RFID/NFC/"metal" detector.
If you wanted to be a touch sophisticated, you could use a tuned (R)CL circuit. The idea would be to charge an LC tank circuit electromagnetically, then watch the ring/decay oscillations. Where each token would be identified by unique frequency. Then, you wouldn't even need contacts!
This idea is like primitive near field communication, or a primitive metal detector. It would be constructed something like the following...
(PI) The Pi has a electromagnetic coil, powered by a dirt simple transistor driver. This is energized with some synthetic AC or pulsed DC signal. This side acts like the primary side of a transformer.
(Token) The token is an identical electromagnetic coil, with at least a capacitor attached. With just this, it should resonate with the well known LC resonance formula when energized. This side acts like the secondary of a transformer.
Operation
When you bring the two coils close to each other (really quite close... like.. basically touching) power will transfer from the Pi side, to the token side. This will (with respect to compatible octaves of the supplied frequency!) energize the token with oscillations. When you remove the primary side drive signal, the token will "keep going for a while" which will, in turn, be detectable by your primary side coil.
Alternatively, adding the second coil also has the effect of basically just adding the token's capacitor to the RPi side capacitor in parallel. This will lower the RPi side LC tank resonant frequency by the amount of capacitance the token holds.
Either method is potentially viable for separating tokens.
You can use low pass filter (pin1-resistor-pin2-capacitor-ground), configure pin1 to output 1 and monitor/sample pin2 until it sets to 1.
Now turn pin1 to 0 and monitor pin2 (sample - monitor time how long time will take) until it sets to 0.
By altering values of resistor and capacitor you will get different time delays which will allow you to distinguish different tokens associated with a particular person.
This solution was used long before ADC became a part of MCUs.
Well, for project of this kind I would use Arduino (or just Atmega8/16/32 chip) -- minimal cost and easy to work with.
Raspbery Pi has so much power that it very wasteful to use for such simple project.
  • \$\begingroup\$ +1 for the top part, as this is still about what I think is the best approach. But -1 for the bottom part. Though I agree with you 100% that the RPi is overkill, It's still not appropriate to criticize it's use for this application. (1) It's doing other things that you probably couldn't do easily with the AVR powered Arduino (namely, record and playback decent audio) (2) If we were allowed to criticize on performance merits, I would criticize the RPi as a whole as a Broadcom publicity stunt that can be out done by any comparably priced Android. (e.g. TracFone Galaxy Sky/J3 - $35) \$\endgroup\$
    – Charlie
    Commented Dec 24, 2019 at 6:43
You can safely pick every second 1% value and get stock from Digikey for 15 cents each.
The 1/4W metal film resistor can go inside a plastic screw-on to 3.5mm plug , soldered and then potted with sub-floor adhesive (Polyurethane) if you want to hide it.
Using a 10k to 20k has enough values. Using a 100k Pullup to Vref allows the same input to be used to detect a logic "0" to wake up the unit, with 10 to 20% of Vdd which will work.
A 0.1uF ceramic Cap can be shunted against the same pin to shunt ESD discharges and prevent intermittent contacts from changing the voltage more than dV/dt=V/RC
  • 7
    \$\begingroup\$ how do you plan to have the raspberry pi measure the resistance? \$\endgroup\$ Commented Dec 22, 2019 at 4:30
  • \$\begingroup\$ @Jasen using an analog port with 10k~20k and 100k pullup and 8 bit ADC can resolve this with a simple algorithm just as Apple products did at one time before ID chips. \$\endgroup\$ Commented Dec 22, 2019 at 5:32
  • 5
    \$\begingroup\$ The Pi doesn't have any analog inputs. \$\endgroup\$
    – Oskar Skog
    Commented Dec 22, 2019 at 9:12
    \$\begingroup\$ This solution would work well for an ESP32, which has the required ADC. \$\endgroup\$
    – Besi
    Commented Dec 22, 2019 at 11:35
  • 6
    \$\begingroup\$ You don't need an ADC to measure resistance. You can also do it with a capacitor, a digital IO pin, and a timer. \$\endgroup\$
    – AaronD
    Commented Dec 22, 2019 at 17:51
