I know that the parasitic capacitance of a chip is pronounced Cdyn. If I apply on some scenario one the chip which will toggle the all of its transistors with two different voltages, but the frequency is the same, does the Cdyn will be the same?
  • \$\begingroup\$ The dynamic capacitance remains the same. \$\endgroup\$
    Dec 22, 2019 at 16:00
  • \$\begingroup\$ Why there is no impact from the voltage applied on the chip? \$\endgroup\$ Dec 23, 2019 at 10:32
  • \$\begingroup\$ Can you help explaining via equations? \$\endgroup\$ Dec 23, 2019 at 11:50
