Look at the picture, which shows a Class C power amplifier (source). What is the role of the resistance in the base of the transistor, and what happens if it's removed? eClass C Power Amplifier
    \$\begingroup\$ The capacitor Cin charges through the base-emitter junction during the positive half wave of Vin and discharges through R1 during the negative half wave. Without R1, Cin will not discharge and will block the base current; the transistor will be cut off. \$\endgroup\$ Dec 23, 2019 at 4:32
4 Answers 4
This resistor provides discharging of Cin. Without this, Cin will charge up to peak voltage of Vin (decreased by Ube junction forward voltage of Q1). As the result the Q1 will remain open all the time, so the amplifier will simply not work.
    \$\begingroup\$ Comments are not for extended discussion; this conversation has been moved to chat. Any conclusions reached should be edited back into the question and/or any answer(s). \$\endgroup\$
    – Dave Tweed
    Dec 23, 2019 at 22:13
A simple answer:
The capacitor Cin fully charges through the base-emitter junction during the positive half wave of Vin and slightly discharges through R1 during the negative half wave. Thus it can be thought as of a "rechargeable battery" connected in series to Vin.
During most of the positive half wave, its voltage subtracts from Vin and it acts as an opposing voltage source that shifts down the base voltage with about 0.7 V. Only at the top the effective voltage is enough to turn on the base-emitter junction and accordingly, the transistor.
    \$\begingroup\$ What if the transistor is a MOSFET? Is the resistor still needed? Because there would be no charging base current anymore. \$\endgroup\$ Dec 23, 2019 at 12:25
  • \$\begingroup\$ Interesting question... that shows a creative thinking... The straightforward answer would be to connect a "diode" network (of a Zener + ordinary diode in series) between the gate and ground... but maybe there is a more original solution... e.g., simply (another) resistor + diode... \$\endgroup\$ Dec 23, 2019 at 13:04
  • \$\begingroup\$ The classic BJT multivibrator exploits the same idea (charging the capacitors through the base-emitter junctions). You can see how this is implemented in the MOSFET multivibrator where there are not p-n junctions... \$\endgroup\$ Dec 23, 2019 at 13:15
  • \$\begingroup\$ It seems the resistor (voltage divider) will do the job: wiki.analog.com/university/courses/electronics/… \$\endgroup\$ Dec 23, 2019 at 14:23
    \$\begingroup\$ With a MOSFET you'd still need something to establish a DC level -- so if you're feeding the gate with a capacitance, you'd want at least a large-valued resistor there. You'd want to make sure that you're not pulling the gate too far negative, as well. \$\endgroup\$
    – TimWescott
    Dec 23, 2019 at 15:22
Summary
Since the input impedance is low when Vbe>0.6V <100 Ohms the base resistor should R1 pulls up more than down to 0V. R1 forces the conduction duty cycle or phase conduction angle to increase. The concept is to pump as hard as possible for the shortest % of time so that the Bandwidth of the filter can reject the modulation noise when saturated.
Removing R1 only reduces the pulse duration when there is sufficient drive as it should be. If there is insuff,drive , it turns off.
This shows with a slider for R1 on the right. You can also remove it and vary the drive level.
other
Class C means pumped LC resonator with practical efficiency 50% to 80% as it only conducts in saturation as a switch for low duty cycle to apply some modulation frequency to the carrier.
Conceptual only enter image description here
It also means "low fidelity" modulation so BP filtering is essential. enter image description here REF
The peak current and pulse width is then increased, no problem.
The example in question is not really useful but just a proof of concept. Whereas the above is more practical of a high efficiency RF AMP.
Cin and Vbe form a positive clamp circuit such that the Vbe = 0.6Vpk at 1mA and 0.7Vpk at >10mA and also the input impedance drops with the base current. Thus the dV/dt=Ib/Rbe for the peak only resulting in a sharp narrow pulse on the peak input if ~2Vpp Increasing the amplitude just saturates the Vce(sat) more and the current and carrier amplitude then increases.
Reference
Advantages of Class C power amplifier.
High efficiency.
Excellent in RF applications.
Lowest physical size for a given power output.
Disadvantages of Class C power amplifier.
Lowest linearity.
Not suitable in audio applications.
Creates a lot of RF interference.
It is difficult to obtain ideal inductors and coupling transformers.
Reduced dynamic range.
Simulation enter image description here
Values not intended to be a useful design, just to show some characteristics. It could be used for FM with a varicap to modulate the frequency and keep at constant envelope.
Crude example with 10KHz pump enter image description here
    \$\begingroup\$ "with near 100% efficiency". Nope. You may be thinking of the class E amplifier -- class C amplifiers can attain higher efficiencies than class A or B, but the nominal waveform on the collector/drain/plate of a class C amplifier is still sinusoidal, so there's still considerable power dissipated in the amplifying element. \$\endgroup\$
    – TimWescott
    Dec 23, 2019 at 4:48
  • \$\begingroup\$ Not what I read circuitstoday.com/class-c-power-amplifier @TimWescott This base clamps with a pulse current during peak only. \$\endgroup\$ Dec 23, 2019 at 4:57
    \$\begingroup\$ "Theoretical maximum efficiency of a Class C amplifier is around 90%". That's at a very small conduction angle, and the smaller you make the conduction angle of a class C amp, the less the power output you get and the less gain. With the 80-120 degree conduction angles cited in your link, efficiencies range from 82% down to 66% (see here). Theoretical maximum efficiency of a class E amplifier is 100%, assuming perfect components. \$\endgroup\$
    – TimWescott
    Dec 23, 2019 at 5:37
  • \$\begingroup\$ I updated my answer to show what a real Class C looks like, unlike the question schematic and my simulation. But they are technically correct as Class C.. TY @TimWescott \$\endgroup\$ Dec 23, 2019 at 5:50
    \$\begingroup\$ Good point on the textbook error just not showing the clamp diode @VillageTech \$\endgroup\$ Dec 23, 2019 at 18:45
In an rf amplifier that prevents parametric oscillation.
The capacitor in series with the base is provided to keep DC off the input from rectification of the drive signal. In a lot of Cb type amps it is omitted, but that isn't proper.
That is all. The ARRL manual for the Radio Amateur discusses this in the rf amplifier section..... At least it used to.
--Shane KD6VXI
  • \$\begingroup\$ The OP was asking about R1, not about Cin! \$\endgroup\$ Dec 23, 2019 at 19:11
  • \$\begingroup\$ I understand what the OP was asking. I dealt with the reason behind the resistor first. My comment about the DC blocking cap was in reference to another post in the chain above me. \$\endgroup\$
    – KD6VXI
    Dec 26, 2019 at 17:22
