Instead of toggling, this circuit throws this error. What does this mean and how do I fix it?
  • \$\begingroup\$ It is level-triggered. So your clock period is probably too long so it is changing the state several times during one period. \$\endgroup\$
    – Eugene Sh.
    Dec 23, 2019 at 19:33
  • \$\begingroup\$ @EugeneSh. I changed the clock's frequency to the maximum available value and I still get this error \$\endgroup\$ Dec 23, 2019 at 19:37
  • \$\begingroup\$ I am not sure how this thing is simulating. Do the gates have propagation delay simulated? Also it is indeed expected to oscillate. So maybe just follow the advise and single-step it? \$\endgroup\$
    – Eugene Sh.
    Dec 23, 2019 at 19:38
  • \$\begingroup\$ @EugeneSh. I looked it up and on the github page it said to run it in single step mode to figure out the case of oscillations and so I did, and it toggled normally like it should. \$\endgroup\$ Dec 23, 2019 at 19:43
  • \$\begingroup\$ @EugeneSh. I don't get the error right away when I set the J and K inputs to 1 at the start, I only get the error when the first toggle is supposed to happen \$\endgroup\$ Dec 23, 2019 at 19:45
Try this instead
Notice there are 2 stages of latches to make the clock edge sensitive.
  • \$\begingroup\$ Thanks, I will take a look \$\endgroup\$ Dec 23, 2019 at 22:06
