Circuit for the problem
I was doing a practice problem. I calculated the correct value for i_a = -2.4 A. But I used KVL on the bottom loop to get R, and got the inverse of the answer that I actually needed. My equation was -5*ia - 6V + 18*-6R = 0. There is no current flow from the current source above to the loop below.
According to the solutions, I needed to use voltage division to get the correct answer, but I was wondering why is this the case? I could get the correct solution with current division but I don't get why KVL doesn't work for this loop.
  • \$\begingroup\$ The current through the unknown resistor is 6/R, not 6R. \$\endgroup\$
    – The Photon
    Commented Dec 24, 2019 at 2:23
    \$\begingroup\$ Photon, you got the answer please post it as one. \$\endgroup\$
    – Juan
    Commented Dec 24, 2019 at 2:24
  • \$\begingroup\$ But yes, this should give the same result as jumping to the voltage divider formula, since the voltage divider formula can be derived from KVL. \$\endgroup\$
    – The Photon
  • \$\begingroup\$ @jsotola because it is a CCVS \$\endgroup\$ Commented Dec 24, 2019 at 2:32
  • \$\begingroup\$ You write " I could get the correct solution with current division" - but how??? There is no current division in the lower loop. It's a simple series circuit! \$\endgroup\$
    – brhans
    Commented Dec 24, 2019 at 2:36
The current through the unknown resistor is not \$6R\$, it's \$6/R\$. So you should have
$$-5i_a - 6\ {\rm V} -\left(18\ \Omega\right)\left(\frac{6\ {\rm V}}{R}\right)=0$$
(I've assumed the blue probe of the voltmeter is the positive probe, because otherwise you're going to end up with a negative resistor value)
(Also, notice that if you had included the units in your equation, you would have seen right away that you were adding a voltage to a term with units of \$[\Omega^2V]\$, so the equation can't be correct)
You will get the same result by using the resistor divider formula
$$ 6\ {\rm V} = -5i_a\frac{R}{R+18\ \Omega}$$
because the resistor divider formula can be derived from KVL and Ohm's Law.
  • \$\begingroup\$ Thanks, I see my mistake now. \$\endgroup\$
    – aX10m
    Commented Dec 24, 2019 at 5:48
