I'm using an STM32 for AC dimming, for which I use a GPIO output (or timer channel out) to drive a triac, whenever I get a zero crossing detection (rising edge). Is there a way to solve this only using timers architecture and without firmware overhead?i.e not using interrupt handlers.
  • Toff -> configurable.
  • Tonn -> remains the same.
    \$\begingroup\$ "I output PWM signal to triac ..." You can't use PWM on a triac. Once a triac turns on it remains on until the next zero-cross. I think you need to edit your question to explain it better. \$\endgroup\$ – Transistor Dec 24 '19 at 10:10
  • \$\begingroup\$ Yes, after each zero crossing I wait for Toff time and the triac is turned on later triac is switched off at zerocross. \$\endgroup\$ – Rohitsam Dec 24 '19 at 10:20
  • \$\begingroup\$ Mains frequency is low (100 or 120 zero-crosses per second). Why not have your code check the zero-cross in the main program loop? \$\endgroup\$ – Transistor Dec 24 '19 at 10:51
  • \$\begingroup\$ It shouldnt be problem , just wanted to know if the stm32 timer architecture is self-sufficient. \$\endgroup\$ – Rohitsam Dec 24 '19 at 13:09
You can put a timer (A) in single shot triggered from an external pin.
This external pin is your zero crossing detector.
You also may need a timer (B) to measure the frequency.
Software still needs to calculate the duty cycle percentage based on the frequency. And set timer A reload to the measured value in timer B.
However, you could use a DMA operation triggered by timer A to copy the capture time of B to the reload register of A. But, you're calculating with those numbers anyway.
Having an ISR called at 50Hz isn't a problem when it doesn't take a lot of time to process it.
| improve this answer | |
  • \$\begingroup\$ It shouldnt be problem , just wanted to know if the stm32 timer architecture is self-sufficient \$\endgroup\$ – Rohitsam Dec 24 '19 at 13:41
