I am using STM32F030F4P6. When I call this function my ADC starts successfully and I can read an ADC value in the ADC callback, but my MCU hangs at this function line. What is the problem?
My code is generated by st32mcubemx and my IDE is IAR. I have a problem with this line. My program prints "OK1" and the ADC runs successfully, but my MCU doesn't print "OK2". This is a part of my main code generated by cubeMX:
/* USER CODE BEGIN 2 */
uint8_t ret;
printf("OK1!\r\n");
ret = HAL_ADC_Start_IT(&hadc);
if (ret != HAL_OK) printf("ERROR Start ADC\r\n");
else printf("ADC start sucess!\r\n");
printf("OK2!\r\n");
/* USER CODE END 2 */
And this is my ADC init:
/* Includes ------------------------------------------------------------------*/
#include "adc.h"
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
ADC_HandleTypeDef hadc;
/* ADC init function */
void MX_ADC_Init(void)
ADC_ChannelConfTypeDef sConfig = {0};
/** Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion)
hadc.Instance = ADC1;
hadc.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV1;
hadc.Init.Resolution = ADC_RESOLUTION_12B;
hadc.Init.DataAlign = ADC_DATAALIGN_RIGHT;
hadc.Init.ScanConvMode = ADC_SCAN_DIRECTION_FORWARD;
hadc.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
hadc.Init.LowPowerAutoWait = DISABLE;
hadc.Init.LowPowerAutoPowerOff = DISABLE;
hadc.Init.ContinuousConvMode = ENABLE;
hadc.Init.DiscontinuousConvMode = DISABLE;
hadc.Init.ExternalTrigConv = ADC_SOFTWARE_START;
hadc.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
hadc.Init.DMAContinuousRequests = DISABLE;
hadc.Init.Overrun = ADC_OVR_DATA_PRESERVED;
if (HAL_ADC_Init(&hadc) != HAL_OK)
Error_Handler();
/** Configure for the selected ADC regular channel to be converted.
sConfig.Channel = ADC_CHANNEL_4;
sConfig.Rank = ADC_RANK_CHANNEL_NUMBER;
sConfig.SamplingTime = ADC_SAMPLETIME_239CYCLES_5;
if (HAL_ADC_ConfigChannel(&hadc, &sConfig) != HAL_OK)
Error_Handler();
void HAL_ADC_MspInit(ADC_HandleTypeDef* adcHandle)
GPIO_InitTypeDef GPIO_InitStruct = {0};
if (adcHandle->Instance==ADC1)
/* USER CODE BEGIN ADC1_MspInit 0 */
/* USER CODE END ADC1_MspInit 0 */
/* ADC1 clock enable */
__HAL_RCC_ADC1_CLK_ENABLE();
__HAL_RCC_GPIOA_CLK_ENABLE();
/**ADC GPIO Configuration
PA4 ------> ADC_IN4
GPIO_InitStruct.Pin = GPIO_PIN_4;
GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
GPIO_InitStruct.Pull = GPIO_NOPULL;
HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
/* ADC1 interrupt Init */
HAL_NVIC_SetPriority(ADC1_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(ADC1_IRQn);
/* USER CODE BEGIN ADC1_MspInit 1 */
/* USER CODE END ADC1_MspInit 1 */
void HAL_ADC_MspDeInit(ADC_HandleTypeDef* adcHandle)
/* USER CODE BEGIN ADC1_MspDeInit 0 */
/* USER CODE END ADC1_MspDeInit 0 */
/* Peripheral clock disable */
__HAL_RCC_ADC1_CLK_DISABLE();
PA4 ------> ADC_IN4
HAL_GPIO_DeInit(GPIOA, GPIO_PIN_4);
/* ADC1 interrupt Deinit */
HAL_NVIC_DisableIRQ(ADC1_IRQn);
/* USER CODE BEGIN ADC1_MspDeInit 1 */
/* USER CODE END ADC1_MspDeInit 1 */
This is my ADC callback:
void HAL_ADC_ConvCpltCallback(ADC_HandleTypeDef* hadc)
if (hadc->Instance == ADC1)
adc_val = HAL_ADC_GetValue(hadc);
Vin = adc_val*0.001;
printf("ADC val:%d Vin:%f\r\n",adc_val,Vin);
And this is my error callback. At this, I receive ADC ERR:2 meaning HAL_ADC_ERROR_OVR. I am getting the ADC value in the callback but this happens.
void HAL_ADC_ErrorCallback(ADC_HandleTypeDef *hadc)
uint32_t adc_error;
printf("ADC ERR:%d\r\n",hadc->ErrorCode);
printf
from an interrupt, and that's what's causing your code to hang. \$\endgroup\$
