After I saw lots of simulations with CircuitLab here I subscribed today. And then I tried to simulate a simple circuit with an OpAmp which did not work as expected because I could not "measure" the current on the voltage rails of the OpAmp.
I simplified the schematic and here it is. When I simulate it the current on RL is between 0 to 15mA and the voltage between 0 and 3.5V. So far ok.
But if I measure the current on the OpAmp + and - rails the current it 0. I would have expected that the current on the positive rail is the same as the outgoing current.
What is wrong here? Does the CircuitLab simulation not work with this OpAmp (from their list) or does the current simulation on the OpAmp rails not work with any OpAmp or do I do something wrong here?
