I have some doubts about how some circuits with transistors are described in electronics textbooks. Let's see an example (taken from Thomas H.Lee, The Design of CMOS Radio-Frequency Circuits).
This books (and all other books I have read about circuits with transistors) uses a convention in which signals in time domain are indicated with small letters. So for instance iout = iout(t).
Let's consider this example with a Small Signal Mosfet model with parasitic capacitances:
The book considers the situation in which a current source iin is put at the input of the Mosfet, and tries to evaluate the current gain. The result of the analysis is this one:
You may see there is the variable ω, which is due to the presence of the capacitances. My question is: how can be this analysis correct? It is a time domain analysis, so it is not correct to say that the voltage drop on a capacitance is 1/jωC * current: we should use integrals.
I think the previous relationship is true only if we indicate with \$i_d\$ and \$i_{in}\$ the fourier transforms of the drain current and input current. But they have been defined as time domain signals.
The book goes on and uses also equations like that of the drain current of a MOSFET in saturation (\$i_d = k(v {gs} - v_t)^2)\$ and always in time domain. How can this analysis be correct? I'll replace all these signals with their Fourier transform: is it true?
