6
I have recently discovered the exciting world of depletion mode mosfets. Curiously, even in this document, I found nowhere that a depletion mode mosfet could be used as a current limiting/inrush current limiting device. But this is strange, because what prevent us to use them like this:
or like this
(with a suitable heat sink of course) ?
To put flesh on bones, I have built a 800V, 10-20 mA PSU. I have a IXTY01N100D depletion mosfet, with 1000V breakdown voltage and 400mA current. It is not so easy to build a conventional inrush current limiter at this voltage. I wonder if I can use this transistor to limit the inrush current in the filtering output cap.
  • \$\begingroup\$ See figure 6, 8 and 9. \$\endgroup\$
    – Oskar Skog
    Dec 26, 2019 at 10:28
    \$\begingroup\$ I vaguely remember this application was mentioned in the AoE vol 3. I don't have it at hand to lookup now though. But you can definitely use depletion-mode MOSFETs as current-limiting devices. \$\endgroup\$
    – anrieff
  • \$\begingroup\$ Another thing about depletion-mode MOSFETs is that they can be used with V_GS > 0. See this IXYS App Note "Depletion-Mode Power MOSFETs and Applications" for more current source circuits with them: ixys.com/Documents/AppNotes/IXAN0063.pdf \$\endgroup\$
    – ErikR
    May 21, 2021 at 14:14
It should work. It's a common use for depletion FEts and several examples in the document you linked to use them as current sources.
Respect the Safe Operating Area though:
You can also make an AC current limiter with two depletion FETs:
  • 4
    \$\begingroup\$ Thank you for your answer, and for the ac current limiting circuit. Yes, it is well known that a depletion mosfet can be used as a current source, but it is not always immediate that 1+1 = 2, I mean, that a current source could be used as a current limiter. Even The Art of Electronics does not evoke depletion mosfets in the chapter related to current limiting. That is what I found strange. \$\endgroup\$
    – MikeTeX
    Dec 26, 2019 at 20:23
