I'm considering using some IRLZ44NS mosfets that I have with an ESP32 that runs at 3.3v. Looking at the datasheet it says:
VGS(th) - Gate Threshold Voltage - min: 1.0v, max: 2.0v
It seems like this will work, but I saw some other posts that refer to people using these mosfets unsuccessfully with 3.3v at the gate.
Here is the datasheet for the specific part that I purchased: https://static6.arrow.com/aropdfconversion/e4de403d6464383ac0f3e8f5420ce415f093cb18/irlz44nspbf.pdf
I want to use the mosfet as a switch to turn something on that also uses 3.3v (probably 1A max current). Figure 3 on the datasheet looks like I could pull up to ~10A with 3v.
Am I misinterpreting the datasheet? It looks like this part should be fine with 3.3v at the gate.
