I built a simple non inverting op amp amplifier with 2 resistors and a TS972IN powered between 0-5V but my output was always set to 5V. I tried several others Op Amp, others resitors and I also moved my circuit elsewhere (I'm working with a breadboard) and none of this changed anything. In order to solve my issue, I decided to build something even simpler, a voltage follower but I have the same behavior, the output stays to 5V...
My circuit with the pinout I use:
