On the datasheet for CD4007 there are schematics for the input protection network:
and the output protection network:
On both, there are 2 diodes connected by a dashed line (D2 on the input and D1 on the output).
What does the dashed line mean?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityOn the datasheet for CD4007 there are schematics for the input protection network:
The dashed line means that the diode is actually distributed across the resistor structure. The resistor is made using a doped region in the silicon, and there is an inherent PN junction between this doped region and the underlying silicon that contains it. So there is really just one diode, not two, but it is neither before nor after the resistor...it is part of the physical resistor structure itself.
