I am using a STM32L Discovery board (monted device STM32L476xx), for a transmit and receive UART operation using HAL libraries. I am using a FTDI chip for serial to usb conversion as I am unable to use the Virtual Com port of the STM.
I have got the HAL_UART_Transmit function working but can not get the similar receive function to work.
My UART handle Definitions void MX_USART2_UART_Init(void) {
huart2.Instance = USART2;
huart2.Init.BaudRate = 9600;
huart2.Init.WordLength = UART_WORDLENGTH_8B; // changed from 8B
huart2.Init.StopBits = UART_STOPBITS_1;
huart2.Init.Parity = UART_PARITY_NONE;
huart2.Init.Mode = UART_MODE_TX_RX;
huart2.Init.HwFlowCtl = UART_HWCONTROL_NONE;
huart2.Init.OverSampling = UART_OVERSAMPLING_16;
huart2.Init.OneBitSampling = UART_ONE_BIT_SAMPLE_DISABLE;
huart2.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
if (HAL_UART_Init(&huart2) != HAL_OK)
_Error_Handler(__FILE__, __LINE__);
I used the following for Transmit function which prints a string.
char bufftr[] = "check\n";
len = strlen(bufftr);
HAL_UART_Transmit(&huart2, (uint8_t*)bufftr, len, 100);
fflush(stdout);
But I can't get a echo working where I transmit what I receive
char test[100] ;
while (1) {
HAL_UART_Receive(&huart2, (uint8_t *)test, 4, HAL_MAX_DELAY);
len = sizeof(test);
HAL_UART_Transmit(&huart2, (uint8_t *)test, len, 100);
This outputs seemingly random characters of the correct length. Please let me know how can I can I get this to work and also how to get UART transmission through the virtual COM port
